Question about Whirlpool WFW9200S Front Load Washer
Hello, I have a whirlpool duet washer, modelwfw9200sq. It is leaking. We had a repair person fix this last year ( just a small rubber tube comes loose) Can you tell me again where this was located on machine? Front bottom?
  • 15,935 Answers
Front - bottom. You must remove the front kick panel to view.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
My Duet washer leaks water on every cycle where there is hot water mixed in.
On the upper right back corner there is an overflow sensor. A tube may have come off it or it is defective. If your washer had a bad shaking episode, check to see if the small tube came off the sensor.
Jun 29, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport washer that is leaking from the back. we just replaces a screw that hold sthe drive motor up bc it broke. it looks ike the water is dripping by there.
Possible that the tub is cracked or there is a dent which must be checked. if the leak, is visible and comes from the tub you can use some good sealer with glue to stop the leak. this can be polished off. You also try with silicon sealing which comes in small tubes and can fix this leak.
Jun 05, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
There's this grey powdery substance on the rubber seal of the Duet washer and inside the rubber seal, not so much on my wet clothes. I'm assuming the rubber seal is slowly disintegrating? I checked all...
I would get in touch with a washing machine repair person as I believe what you may have either a bearing disintegrating or the spider, the contraption that holds your drum horizontal and allows it to spin,may be corroding. It's called a spider, it's aluminum, and it's got only three legs but when those legs break, the plastic drum and other expensive things often suffer damage as well.
We had this experience this spring with an Inglis washer which is a sister set to the Whirlpool Duet. If the spider is corroding or a bearing is going, and changed before it breaks, it will likely save you about $600 on your repair bill. Remember to compare any repair cost against the cost of a new unit including the age difference. Washing machines only last 7-10 years now... they just aren't built like they used to be.
Nov 29, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking from door area
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Sep 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9200S Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
