Fan broke on my air conditioner model Asp24dad1. I have in out and the shrowd off and the retaining nut off, but cant move the blade off. How do you get it off? Is it treaded? Is there an exploded view I can see thanks so much! Neil
  • 70 Answers
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
Sanyo propellor fan blade needed
I have the SAME EXACT unit and also need a fan blade - and Sanyo told me the same thing!
Jun 20, 2010 | Sanyo CMH3172 Air Conditioner
Install new fan- condenser fan broke-how do i disassemble t install new fan. I have the part
generally it has a nut on the fan shaft that undoes in the same direction as the fan rotates
Apr 22, 2010 | Amana ACE185E Air Conditioner
Carrier central air unit is shaking and broke a fan blade off inside the unit
TURN IT OFF! You're gonna need a new fan blade! Motor MAY be ok, and hopefully nothing was damaged by the flying blade. Just happens but not often - you're just lucky.
Sep 07, 2009 | Heating & Cooling
Cant remove cooling fan shrowd
how to remove a cooling fan and shrowd on a 2005 chevy cavalier
May 01, 2009 | 2005 Chevrolet Cavalier
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Air conditionder
you can replace the blades but they come as a set. you cant get a single blade. As for the shutter you just have to get it replaced.. I can help you find the spares online if you like..
Jun 16, 2008 | Carrier BCA101R Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
