Question about Westinghouse L2046NV Monitor
I can't reset the resolution on the monitor every time I try it goes blank.
  • 2,973 Answers
Are you teying to set the resolution from the Windows Control Panel? If not then try that. Right click on the desktop and select Properties->Settings. Here you will be able to set the resolution. Do not go to the max in the first go. Start by setting it to 1024 X 768 or whatever is the nearest. Then you can keep going higher till you stop seeing the alphabets. Set it to a comfortable resolution. If you are doing it this way only then go to Control Panel->System->Hardware->Device Manager->Monitor. Here delete the drivers for this monitor and then reboot. Come here again and Scan for New HW. Windows will automatically load its drivers and then set the comfortable resolution as explained above.
Posted on Aug 28, 2010
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
I am trying to connect my old gateway to an insignia ltdvd19. I have run a VGA cable from the pc to the VGA port on the side of the monitor and was given a "no support" message on the monitor. ...
The resolution of the video output is most likely not supported by the display you're connecting it to. The widows boot logo is a lower resolution then it switches to a higher resolution after that. Can you connect another monitor to the system at the same time? You could then adjust the resolution to the second monitor to a lower resolution until it starts working.
Oct 25, 2017 | Computers & Internet
Sumvision CYCLONE micro: after adding 1080p resolution in settings, TV screen become blue, no CYCLONE menu available at all. Please help
Your best bet is to completely unplug the TV from the power source, after turning it off, leave it unplugged for a good 2 minutes and try it again.
Thanks,
Tim
Oct 28, 2010 | Video Game Consoles & Games
Trying to run monitor from my lap top and goes in to autoconfig and I see my desktop, when autoconfig is complete, I get blank screen.
In general more info is required, but most likely this is an issue with your display settings. Try the following:
1) Try pressing the Fn and Display buttons (at the same time) on your laptop. Try it once, twice, and then a 3rd time.
Chances are that your laptop is displaying in a resolution that is not completely compatible with your monitor, so when the display settings are switched from laptop LCD and montor, to monitor only, the resolution should adjust automatically.
2) If that doesn't help you, try lowering or adjusting the resolution on your laptop. If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust it. If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know what happens!
Feb 16, 2010 | Acer AL1912 19" LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Westinghouse L2046NV Monitor Logo
125 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
