FixYa.com
Tags:
Compaq ProLiant ML370 G3
Hardisk have difrent amount
posted by malo_maloin on May 07, 2008
hi all
i have client using Compaq ProLiant ML370, there is 3 hardisk on that server,c:\36,4 d:\36,4 e:\36,4 using 2003 server the priblem is?
1. The total caacity if you see in device manager of c,d,e must be 90 or more but i just see that just 64,7, could somebody tell me?
2. why a icon in the hardisk C:\ is different from othe hardisk?
thanks
regards
malo
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 07, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 88%, 1054 votes
Because Compaq has a hidden partition on you're C:\
Stored in that hidden partition is Compaq's restore drivers & software. If & when you need to run the restore CD on the Compaq, the restore CD enter's that partition & uses the software to help in the process of restoring the C:\ drive to factory settings. (This is normal for most Compaqs).
Mike
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Cases problems?
PC Cases
cobra and midland cb
i have a cobra 23 plus cb and a... Answer This...
PC Cases
installing mobo
I have an EVGA nForce 650i... Answer This...
PC Cases
case 990 three point hitch
I have a case 990 and the three... Answer This...
PC Cases
having the problem with...
iam facing the big trouble with... Answer This...
PC Cases
homesite of bestbuy.com
On bestbuy.com when i go to... Answer This...
Repair Service
Find PC Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
