Just replace shocks and 1 spring assembly on kenmore 41743042200 washer tested in spin cycle but did not work. what could be the problem
  • Washing Mach... Master
  • 2,254 Answers
You must have forgot to connect the lid switch harness or you broke the lid switch while you were working on it
Posted on Aug 28, 2010
  • Sal DeAngelo Aug 28, 2010
    forget what i just told you,i was helping someone else with a top load stack washer and i didn't notice you had a front load washer,this doesn't help you
    the problem you're having is the spider gear is rotted through,you used to much detergent and it eats the rear bearing,when it goes into the spin it's very noisy and the tub bounces all over,time for a new washer,the sider gear is around 500 bucks and that's most likely what broke the shock
Kenmore washer H3 vibrates and makes a lot of noise during the spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 07, 2010 | Kenmore HE3T Washer
Kenmore clothes washer makes a knocking sound at
Feb 05, 2010 | Kenmore 22422 Top Load Washer
Kenmore HE2 washer, extreme vibrations in spin cycle.
Jan 04, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore washer model 41743042200 when it is in the spin cycle it sounds like a bearing is going bad. Can someone confirm what the problem may be. Washer works and sounds normal in all other...
The washer may emmit a low whisteling sound during the spin. It is causd buy the air whisteling thru the holes in the wash drum. The bearings are not easily serviceable, you can check them by grasping the agitator and shaking it slightly back and forth. If you feel a little clunking then you may need the spin busnings replaced ($15-20 parts and a $80 tool)or a new machine.
Nov 21, 2009 | Washing Machines
My Kenmore front load washer just bgan to goes out of balance
Oct 08, 2009 | Kenmore 43142 Front Load Washer
Kenmore he2 washer shakes violently
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Spin cycle will not spin upright, when on a 45 d angle it spins.
Mar 14, 2009 | Kenmore Washing Machines
Kenmore Washer makes noise at start of the Spin Cycle
its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Nov 10, 2008 | Kenmore 22422 Top Load Washer
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
