Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
The top part of the frig does not keep the temperature at a constant temperature
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Gasket between frig and freezer is darkening due to very hot surface on divider between sections
If it is that hot you really need to get this checked out ASAP. It could become a fire hazard.
Mar 12, 2014 | Admiral Refrigerators
It keeps beeping and no temperature display......
Hi Mark, I am happy to assist you. When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the beeping, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging the unit or flipping the household circuit breaker. It is important to wait approximately ten minutes and then turn the refrigerator on. If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Jul 30, 2013 | Frigidaire Refrigerators
FRIG KEEPS BEEPING BUT DOORS R CLOSED TIGHT
Not knowing the make and model of your fridge, I would suggest reseting the fridge and freezer temperature settings, inside your fridge. With some fridges like Fisher & Paykel, when the power is cut to the fridge, it will beep until you select the temperature level inside the fridge.
Failing that, a constant beep is a warning code to alert that a fridge component has failed.
Ash
Sep 11, 2011 | Refrigerators
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
Kenmore top freezer frig
check your start relay on compressor. If that doesnt solve it then you need a new compressor. This is all based on the facts the you said the unit is running all the time
May 27, 2009 | Kenmore 63182 / 63184 Top Freezer...
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
FRIDGE SIDE SAMSUNG REFRI NOT COOLING
empty frig side totally shelves too remove white plugs too lite and both panels leave1 screw in upper narrow panel remove 2 shelf supports in middle of frig carefully pull on top of wider bottom panel with constant pressure its frozen behind i took hair dryer once seperated enough at top and dethawd till panel was removable totally thawed reassemble frig works fine
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Constantly runs and what is the normal frig. temp?
37-39 sounds like a problem check the freeezer coil for frost buildup
May 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
