Question about DCS PHFS Phoenix III Outdoor Patio Heater
I need to replace the thermo couple on an +10 year old Phoenix Professional Patio Heater. Is this a standard item or are they different by heater model?
  • 70 Answers
A thermo couple is universal can get at lowes/Home depto
Posted on Aug 28, 2010
  • MARK BIALLAS
    MARK BIALLAS May 12, 2011
    No you can't. Patio heater thermocouple are not universal. There are about 5 different thermocouples unique to there specific valve. We stock all parts for the DCS Phoenix. WWW.THEHEATERGUYS.COM
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Patio heater goes out
If your patio heater goes out when you turn on the pilot and let go, this is usually a worn thermocouple. They last between 1 year (if you are unlucky) up to 6 years and are a consumable item. Found this site very useful patio heater problem solving.
May 24, 2012 | Dayva HS041 (LP) Open Flame Gas Patio...
Portable patio heater is a DCS Phoenix Professional Patio Heater Model PHF8-DWBZ-L. Burner ignites and operates for a few minutes. Then teh flame is reduced to a short yellow flame. Regulator is covered...
The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
Hope this helped answer you question and provided, at least a quick fix solution.
Apr 21, 2011 | DCS PHFS Phoenix III Outdoor Patio Heater
Need parts list for a Sunjoy brand model G-ph018pss stainless steel patio heater.
Patio Heaters Genuine Spares And Replacement Parts
This is the best that I could find. I believe that items like this are imported from China with no support stock of spare parts. In the old days, one could locate the manufacturer in the US and buy any individual part he wanted.
Gary
Feb 21, 2011 | Lakewood QT1 Patio Heater
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a Phoenix professional patio heater that the pilot light will not light.
If the pilot will not light at all, then first check to make sure your propane cylinder is not empty. Second disconnect the tank and reconnect, but very slowly turn the tank valve back on and try relighting it again. Third, if the above two do not solve it, then get a can of compressed air (like you use to clean computer keyboards) and blow out the dirt/spiderweb from the pilot orifice, where the pilot flame normally lights. It may just be plugged/dirty. Douglas
Oct 08, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
Flame out on a DCS Patio Heater
thermo-coupler (cheapest to fix) or valve
Jan 30, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
The heater will not stay lit unless you hold the button in. Thanks, Susan
Try cleaning the thermo coupling, sometimes soot will cover this and it cannot detect a flame, light abrasive sandpaper will work. ( The thermo coupling is what the pilot flame touches
Jan 04, 2010 | Stainless Patio Heater - Steel Outdoor...
Heating & Cooling Logo
458 people viewed this question
Top DCS Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
