Question about Magic Chef MCBR440 Compact Refrigerator
How do you set the temperature of the freezer...my freezer freezes at the mid setting on the control dial.
  • 4,793 Answers
Get a thermometer and set the freezer to -18C and a fridge to +5C.
these are the optimum temperatures for keeping food.the internal knobs are for guidance once set,to adjust to seasonal changes.summer to winter.....and for when you refill
Posted on Aug 28, 2010
I have a Danby fridge with a numbered temperature dial. Does the higher the number mean a colder temperature? All my stuff keeps freezing
Keep your freezer to the mid point, and your ref to mid.
Wait 24hrs for results. If your refrigerator is still freezing, you may need a new thermostat. Get the model number, and go to searspartsdirect.com and look up the thermostat. Sometimes it's also referred as cold control.
Apr 18, 2016 | Danby Refrigerators
HOW DO I ADJUST REFRIGERATOR TEMPERATURE
    1. Refrigerator Adjusting Temperature Controls. At initial startup both fresh food and freezer controls should be set at the normal setting or mid point settings. Temperature controls can be found in the back of the fresh food compartment, near the top of the fresh food compartment, or on the dispenser panel.
      Refrigerator Adjusting Temperature Controls - GE Appliances
      products.geappliances.com/appliance/gea-support-search-content?contentId...
    Feedback
  1. Refrigerator Temperature Control Dial - What Do The ...
    removeandreplace.com/.../refrigerator-temperature-control-dial-what-do-...
    Mar 4, 2015 - The more food you have in your refrigerator, the more stable thetemperature will be. Set the thermostat to the middle of its range and leave it for ...
Nov 28, 2015 | Refrigerators
Can't fined the proper setting for the freezer dial?
Almost all freezer controls are manufactured to control temperature to the proper temperature control if you rotate CCW , notice the position and then rotate CW, notice the position and then go the the mid position. If temperature is not maintaining the required temperature, you may need a new temperature control thermostat installed. Before you replace the thermostat, check to make sure you have not overloaded the freezer compartment and, If you have an external condensing coil, that it is lint/dust free. Often times people seldom clean the external condensing unit and causes the loss of freezer temperature control. It is important to keep the condensing coil clean because that is where the heat is rejected to the surrounding air. Hope this helps.
Sep 25, 2014 | Cars & Trucks
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
Magic Chef MCBR440 Compact Refrigerator Logo
174 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
