Question about Kenmore Dryers
Does not heat, runs o.k. otherwise - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 28, 2010
My dryer is not heating up so its not drying the clothes. It otherwise seems to b running ok.
call a technician to get the heating side working
you did not mention if it was power or gas ---most important information
Feb 13, 2017 | Dryers
How to fix Whirlpool duet dryer runs but does not heat?
The element is broken, you can pick up a replacement from any wholesaler of plumbing/electrical/appliance parts. Otherwise, there could also be an in-line fuse. if you look up your appliance on the internet ( a silver sticker on the lip or groove around the perimeter of the door has the serial number and model number) you can search the exact model number and find the manual, and then see if an in-line fuse exists. Otherwise, replace the heating element
Graham
Aug 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
No heat but blows cold air
Not if the engine is getting up to normal temp. Could be low on coolant or a problem with the heater core or a blend door under the dash.
Jan 24, 2014 | 2001 Saturn L-Series
Awz 9813 whirlpool
Check your thermal fuse, if that is ok make sure that your heating element has continuity. Also check your cord you need 240vdc at machine to operate, it will run with 120vdc but needs 240vdc to also heat.
Jul 31, 2013 | Dryers
Warm Mist HWM-2030 Humidifier: DOES NOT GIVE OFF VAPOR...
If the unit runs normally otherwise, but doesn't give off vapor, then your heating element is the culprit. i.e. if fan runs, switches in normal positions, indicating lights on, etc.and restart slide switch depressed and no mist, then, yes the heating element is the source of the problem. It may be bad, or otherwise it may just be scaled up from hard water, and require cleaning.
You may refer to your users manual, or if you no longer have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this answers your question.
kcomp1863
May 18, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Not heating food
likely the magnetron is gone. check your warranty on this part with you book. otherwise it is a costly repair.
Oct 04, 2009 | Amana Radarange Microwave Oven
No heat but dryer works normal otherwise...
motor only needs one breaker to work element needs both they may look on but flip them off hard then on 3 times.... I know you say the motor is running... JUST DO IT IT if no heat then check element
Aug 12, 2009 | Dryers
The frizer outside is very hot. kenmore model 71192107 year7/02
The condensor coils run around , up , down , the sides of the freezer . This heat is the heat being pulled OUT of the inside , which makes the freezer cold . Freon (refrigerant) attracts heat , which causes the frost in refrigeration . But , the heat has to dissapate , otherwise , hot gas would pump thru the system , and , no cool . A freezer does not get cold , Heat is pulled out , causing food to freeze . So , hot is good .
Aug 01, 2009 | Refrigerators
It wont heat up
Check to make sure that both legs of the 220V feed are presnt. The motor will run on only one leg. Otherwise, on that model, check the thermal overloads mounted on the heater box, and also check the heating element for continuity.
Dec 11, 2008 | Kenmore 65924 Electric Dryer
Dryers Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
