Question about Vivitar Vivacam 5399 Digital Camera
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a 128MB card and still the camera does not see anything. Help!
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 29, 2010
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Cannot download from vivicam 5399 NO DRIVER FOUND
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Oct 30, 2010 | Vivitar 5399 Digital Camera
Put sd card in vivitar 5399 but not reading it
Receiving no response in over a month, I assume this is no longer a problem.
May 28, 2010 | Vivitar Vivacam 5399 Digital Camera
I bought a new SanDisk 4GB SDHC Card. When I put it in the camera the camera comes on but will not go past the intro screen "Vivitar-We makeit easy". If I take the Card out it works. Is the 4G card not...
I haven't heard of anyone having this problem, and they're all using 4gb Scandisk cards, so...I would suspect that the card is bad. Try to get it exchanged, but first try an older, card you used before, to make sure the camera is ok as far as detecting a card. Hope this helps.
Apr 18, 2010 | Vivitar ViviCam 5100 Digital Camera
Brand new vivitar 5018 keeps showing insert memory card but when card inserted it reads card not ready and flashed between 2 screens...please help. I have tried 2 memory cards, one 64MB SD card and one 4GB...
Vivitar cameras are known for there inability to function normaly. Alot of these and many more problems I have encountered are manufacturer problems and can not be fixed on your own. the best thing to do would be to contact Vivitar and see if they can give you a refund or replace it. it is best to call but as I do not know the number here is a link to their website. I hope this helps -Richard www.vivitar.com
Mar 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
Printer will not read card
Try to use your card in a clean computer and run a virus or malware test on it. Make sure that the card has no unwanted hidden folders that may contain virus files unblocking the card from being accessed by your printer.
Dec 29, 2009 | PNY Optima High-Speed 512MB Secure Digital...
Camera can no longer read the Sony 16G Memory Stick Pro Duo
Sorry but it sounds like the card is pootched. Very common problem with these sticks. Best bet is to get multiple 2gb sticks to ensure that when one goes (and one will) you won't lose all of your pics
Sep 15, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I bought a 4GB Kodax memory card for my vivitar digital camera and it's not working. It said card error.
Check the little tab on the side of the SD card to make sure it is not locked. If that doesn't do it, take the batteries and SD card out, wait 30 seconds, then re-insert the batteries and SD card. If all else fails, read the manual on how to format (or reformat) an SD card. In either case an pictures stored on the card will be lost.
Jul 14, 2009 | Vivitar ViviCam 8400 Digital Camera
Vivitar Vivacam 5399 Digital Camera Logo
85 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
