Question about Motorola Mobility L6 Cellular Phone
Reduce the volume in L6 model
Give me the process for reduce the sound
    Novelist:
  • 124 Answers
HI padmasree,
First i want to say u that L6 model have got some disadavantages than in L7. 1st iit dont hv got MMC slot.
IN L6, u hvnt got any shortcut button to control the volume.
For controlling volume, u must be in standby(normal) mode. In that mode, u can increase or decrease volume by left and right key respectively. U can also control volume by same keys when u press menu key while playing mp3s or videos or pictures.
I m looking for ur kind feedback. And dont forget to rate my solution.
Be sure to post a clarification request for ur problem after u got ur problem solved.
SAJAN (sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
Posted on May 07, 2008
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
How can I sharpen my picture and correct the volume as it sounds like it is in a tin can?
Turn off all the picture processing settings. They just add noise anyway. Set noise reduction to minimum/off. Switch off Overscan. Reduce the sharpness control until any trace bright edges to dark objects over a light background is reduced to not visible. The picture is the sharpest and most detailed it will ever be when it first comes in to the set. Getting rid of all the extra processing will allow you to see the real detail of the picture.
Sound quality is most likely down to a limitation of the thin speakers in modern flat screen TVs. If the TV has bess and treble controls, try reducing the treble and increasing the bass. In the end though, thin speakers = thin sound. There's a lot of folk buying soundbars to go with their new TVs. That might have to be your solution too.
Oct 02, 2014 | Televison & Video
I have no manual of my motorola phone..k..but the volume of my motorola l6 is so low when i'm using mp3 songs how to contol the volume of this phone motorola l6?
To get the maximum volume from your MP3 player you have to increase the ringer volume. To get the best sound you should use either earphones, headphones or blue tooth ear bud. Below you can download a manual for your phone (page 68) explains how to control ringer volume.
http://docs.phonedog.com/motorola-l6-manual-3634.pdf
Mar 14, 2011 | Motorola Mobility L6 Cellular Phone
Motorola mobile phone model L6 phone does not
first try to change sim card if this helps then good else your phone is in black list and can be repaired at unlocking shop so take it to it
Aug 23, 2010 | Motorola Mobility L6 Cellular Phone
Volume cannot be changed.Full Volume even if reduced or muted
You need to first find out what chipset your on-board card uses my friend. Check all the documentation to find out. You will need the exact set. Now search the net for an updated set of drivers that matches your operating system (XP SP1/2 etc). Now go to device manager and delete anything which has sound connections (MIDI Interfaces, MICs etc..). Now click the 'scan for changes' icon in device manager. Use the new drivers you downloaded.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Voice Problem in Motorola Mobile L6
first of all check your profile(volume)settings .If still your are having that problem then it should be a problem in speaker itself that is speaker may be damaged .its better to replace a new speaker.
May 23, 2008 | Motorola Mobility L6 Cellular Phone
Cant hear an incoming caller talk
Press the navigation key: right arrow to increase volume, left to decrease volume. Maximum volume is 7.
Dec 11, 2006 | Motorola Mobility Earwrap Handsfree For...
Motorola Mobility L6 Cellular Phone Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
