Question about Lexmark X4550 InkJet Printer
I am trying to add my Lexmark X4550 printer to my Macbook's list of printers. My laptop recognizes the printer is there but when asked to select a driver, the X4550 is not an option. I tried to print something and when the printer queue came up, it immediately paused the command. I clicked 'Resume printing' and it immediately paused itself again.
  • 10,319 Answers
If not an option to retrieve that driver this printer will not operate on your current Operating System. you must have XP or a lower version to work this printer unfortunetly
Posted on Aug 28, 2010
Aswell as my daughter I've installed the drivers (Vista and 7) of the Lexmark x4550 wireless, but she can only print when my laptop is 'on'. How can she print without the use of my laptop.
All you need to do is to remove the printer currently added on your daughter's laptop(most likely it is the printer installed on your laptop)and then add the lexmark printer manually on your daughters laptop. Make sure when you do this your laptop is turned off. If this won't work, that means that the laptop of your daughter does not detect the wireless printer.
hope this helps...
Sep 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
I have a Lexmark X4550 printer. Recently, when I try to scan it asks me to enter a PIN. I don't recall ever setting a PIN. How can I reset it and/or set my printer to not require it?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
The printer does not print and i get a message that says system cannot find file
Try to reinstall the printer driver on your computer. Please visit the Lexmark website to download and install the Lexmark X4550 Printer Driver on your computer. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Aug 19, 2011 | Lexmark X4550 AllInOne InkJet Printer
Lexmark x4550 scan problem
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/g8G3VP. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 13, 2011 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X 4550 scans ok but when i try to print, "incorrect port detected" comes up as a fault, i have it all connected ok and in a usb port. can anyone help please.
look under control panel ,printers and faxs, right mouse click on your printer displayed in the list , then from the list, select properties . Next from the tabs on top , select ports, from the ports list select the usb connection on the list or if wireless you should have a lexmark connection port showing as well. Its just you havent got the correct port selected.Dave
Jun 06, 2010 | Lexmark X4550 InkJet Printer
Need to install Lexmark X4550 but only have MAC disc am on vista
Are you trying to install the Lexmark X4550 to your Mac computer? What is the exact OS of your Mac (i.e 10.3.x; 10.4.x or 10.5.x)?
You have to make sure that the pinter is compatible with the OS that you have.
I don't have a doubt with the printer since you mentioned that it worked with XP. To install the printer to your Mac, please follow the steps below:
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
If the printer will not work, you may download the driver from the Web and install it. Here, I have provided you the link where you can download the printer driver:
http://www.findmysoft.com/drivers/Lexmark-X4550-1-0-11-1-printer-driver.html
Just click the download button and install it.
Have a great day!
May 13, 2009 | Lexmark X4550 Multifunction Wireless Color...
Printing problem
To delete the file from printer cue, unplug printer, restart computer with printer unplugged, and delete file.
If it still does not work after deleting files, reinstall all printer software using software CD provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 12, 2008 | Lexmark X4550 InkJet Printer
X4270 all in one printer driver needed for a new Mac notebook
You CAN you your X4270 with your mac, its just a bit of work.
You may need to download the gutenprint/gimp drivers and install them. Which you can find at this link: http://downloads.sourceforge.net/sourceforge/gimp-print/gutenprint-5.2.4-rc1.dmg?use_mirror=superb-west
Once these are installed, do the following:
Before attempting this, ensure that your X4270 is plugged into your Mac and powered on.
1: Open "System Preferences" under the Apple menu in the upper left corner.
2: Click on "Print & Fax"
3: Click the "+" to add a printer
4: "Lexmark 4200 Series" should show up under the default tad of add printer, select it by single clicking.
5: If you wish you can change the name and give a location below
6: Where it says "Print using:", select: "Select a driver to use" This will bring up a list of printers
7: Search or scroll until you find "Lexmark Z43-CUPS+GutenPrint", select this by single clicking.
8: Press the "Add" button at the bottom and you should be done, if may ask you to step through a few more things, but it will be trivial.
Please note that this is not a perfect solution. I seem to have to print one page at a time, which is a pain, but at least I didn't have to buy a new printer. This could be a problem with my printer only, or it might just be a setting that I haven't found yet, so look around see if you can find it.
Also, you will not be able to use the scanner on your mac as far as I can tell, and I don't remember if the copy/fax works.
May 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4550 InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
