Question about GE WPXH214A Front Load Washer
I have a wpxh214a ge washing machine.approximately 5 yrs old.suddenly vibrating like crazy.took off front lower panel noticed broken left damper(at the foot where plastic bolt goes through damper.Oddly at the same time it won't pump out now.it had been working fine until that load.(did 2 that same day and worked fine).
  • GE Master
  • 43,501 Answers
The machine shut down bwcause of the vibration and if you unplug it it will reset...
but you need to get those shcks changed... they are not that hard to cchange and change both sides right of way...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
Washer has recently started to vibrate significantly during spin cycle. The vibration occurs on all load sizes and types. If washer is run empty it does not vibrate during spin cycle. Can this be...
I would check to make sure the machine is level. Check and see that all four legs are firmly planted on the floor with the lock nuts securing the legs. Open the door and look at the wash tub. It should sit centered in the door. It should not sag in any direction. Then remove the bottom panel and check the shocks to see if any one is broken. Hope this helps you.
Jan 08, 2011 | GE WPXH214A Front Load Washer
My GE front loading washer model # WBVH6240HWW just recently started having vibration problems while in the spin cycle. Its vibrating badly and its very loud. What is causing it.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 07, 2010 | General Electric WBVH6240HWW Front Load...
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
I have a loud banging, it twisted the front rubber seal to the door. I tried to look inside but I can't get the top portion to lift. It feels like something is about to break. It seems out of balance, is...
IF THE DOOR HOLE AND THE TUB HOLE ARE NOT ALIGHNED YOU EITHER HAVE A BROKEN STRUT OR SPRING. REMOVE POWER THEN THE LOWER PANEL, LOOK THROUGH PANNEL YOU SHOULD SEE TWO STRUTS GRAB THEM AND SEE IF ONE IS BROKEN .IF NOT ITS PROBEBLY ONE OF THE SPRINGS ON TOP, GOOD LUCK!
Jan 16, 2010 | GE WPXH214A Front Load Washer
I have a servis easilogic 1300rpm.model number M9503s.It is 3 yrs old and has been working perfectly until i went to use it today.all the lights have come on on the control panel but nothing responds.whats...
It is probably a control board fault, unless you can find a specific fault, then normally the only solution is to replace the board.
Hope this nhelps.
Dec 15, 2009 | GE WPXH214A Front Load Washer
Washing machine suddenly stopped working only 17 months old
unplug from the wall about 1min then plug back in this will reboot the cpu on the machine
Aug 23, 2009 | GE WPXH214A Front Load Washer
Kenmore Elite HE3T Washer sounds like a plane taking off? (Loud!)
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 20, 2009 | Kenmore 24032\24036 Top Load Washer
Door locked
To manually unlock the door lock system, perform the following steps. Power off the mains.
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Mar 19, 2009 | GE Washing Machines
Washing machine
Your outlet filter is blocked, check this out and clean it and refit. The filter requires periodic cleaning according to your use. For most machines the filter door is at the front bottom; just look for it in your users' manual.
Jun 20, 2007 | GE WPXH214A Front Load Washer
GE WPXH214A Front Load Washer Logo
131 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
