Question about Panasonic Lumix DMC-ZS3 Digital Camera
My TZ7 says that it has a system error (focus) and will not take pictures, view pictures or menu and the shutter will not close when turned off. Help!
  • 4 Answers
Here's a fix I got from Panasonic, I figured I would post this since I haven't seen this anywhere on the web and this post was the highest hit on google
Based on the information that you have provided, we suggest that you perform the following operation:
1. Turn off the camera 2. While off, turn the zoom button fully to the left or right (hold for about 3-5 secs) 3. Release then turn the camera back on... At this point in time the lens should retract. If it does not, repeat the previous steps however, press the zoom to the opposite direction than you did the first time around. If this does not resolve the issue, we recommend the product be sent to our Customer Service Center.
This seems to work for me. The lens retracted back in place and my camera resumed working.
Posted on Oct 10, 2012
SOURCE: Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
I read this and instead of pulling it apart, i just shut it off and wacked the bottom of the camera against the palm of my hand until screen was back to normal and shutter and zoom started to work properly again.
Posted on Aug 26, 2007
  • 172 Answers
SOURCE: lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Posted on Apr 05, 2008
  • 11967 Answers
SOURCE: we adjusted the settings to fast shutter speeds
Someone has applied force to the lens and that's what is causing your problems, not the settings adjustments you made. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 23, 2010
  • 11967 Answers
SOURCE: I have a Panasonic DMC-ZR3
Posted on Aug 24, 2010
lock123
  • 6831 Answers
SOURCE: I get an error message...system error (focus)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
My screen is black
Does the screen work in menu mode or playback? If so then the shutter may be stuck in the closed position. Compact and bridge cameras work on "live view". The picture is live feed from the lens. Obstruction to the sensor (usually the shutter) will prevent live view.
Jan 19, 2014 | Fujifilm Finepix S2980
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
Can not see through the view finder / black screen with menu on top
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 27, 2010 | Canon PowerShot S2 IS Digital Camera
Pictures are appear blurry when reviewing them. I focus the camera object appears clear after I snap the picture it becomes blurry as it is being save for review.
Question : Why are my pictures out of focus (blurry)? Answer : This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
  • The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
  • The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
  • The subject was not within the effective range of the flash. Each camera has an effective flash range.
  • The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
  • The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
  • The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
Dec 08, 2009 | Kodak EasyShare Z740 Digital Camera
Stopped focusing properly. Now get only black when looking through view finder or on screen. other features seem to be working correctly
A stuck shutter is a common failure mode for some model digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 13, 2009 | Canon PowerShot S2 IS Digital Camera
My canonpowershot SD750 digital camera is coming as a black scree
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 02, 2009 | Canon PowerShot A550 Digital Camera
Shutter button +++
Hi your camera having problem inside , you may visit fixia authorized repair shop near you , just enter zip and then go , can find down right side.
Jan 08, 2008 | Canon PowerShot A520 Digital Camera
The pictures I take with my Kodak digital camera are not clear
One or more causes may result in unclear (blurry) pictures. Some common causes and suggested solutions are listed below. The lens is dirty. Clean the lens according to the guidelines for your camera model. The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera model has recommended distances for normal, telephoto (zoom), wide-angle, and close-up pictures. The subject was farther than the effective range of the flash. Each camera model has an effective flash range. The camera did not autofocus or autoexpose the picture correctly. For best Autofocus/Autoexposure function, press the shutter button halfway down and hold. When the AF/AE Indicator (Ready Light on some cameras) turns green, press the shutter button the rest of the way down to take the picture. If the yellow light blinks, release the shutter button. (On some models, the light will also blink yellow if the shutter speed is too slow.) You did not use the LCD screen Preview feature to take a picture in Close-Up mode. When the camera is in Close-Up mode, always use the Preview feature, both to confirm focus and to aim the camera properly. If you do not do this, the viewfinder will not show you an accurate view of the picture because of parallax error. The subject or camera moved while you took the picture. Place the camera on a flat, stable surface, and hold the camera very steady. Or use a copy stand or tripod – especially advisable at telephoto or high-zoom settings, or in low light.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
845 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
