Question about Danby DWC440 Wine Cooler
Where canI get the PTC start assist for my Danby DWC 440 BL Samsung compressor DD152 C-L1U2?
5 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I need a start relay for a Kenmore (Danby)
Hi, I'd personally just go and put in a aftermarket start relay and overload. Look up part # IC41 or IC81, or even a rco/hs810. it's been a while since I've used them, but they work. Unless the unit is under warranty there's no consiquence. If you have warranty, these parts will void said coverage. Good luck, hope that helps
Posted on Oct 19, 2009
  • 31 Answers
SOURCE: Our danby dwc 283bls is not cooling. The motor
The motor will run pretty hot. How old is the unit? It probley just needs to be cleaned out. Most problems with cooling is just clogged up coils. Is the motor just hot or is it vibrating to?
Posted on May 22, 2010
SOURCE: Danby refrigerator M# DAR452BL does
I have the same model and am needing parts for it. Did you have any luck finding a parts house?
Posted on Aug 08, 2011
allinallelec
  • 407 Answers
SOURCE: danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
check compressor relay..
also ok so check condenser coil heat no heat so check gas lickeg on capilary tube or" condenser lickeg or" jam capilary tube.
Posted on May 30, 2012
BCFA27B need replacement for QP2-4.7. i think it's the starter.
Shop for Refrigerators need repla... on Google
Oasis 036056?001 R...
$18.55
DrinkingFoun... Refrigerator Compressor S...
$25.32
Sears Parts D... QP2?4.7 ' Danby Refrige...
$15.75
Google Trusted StoreAppliance...
Danby QP2?4.7 Refrigerator St...
$17.50
Google Trusted StoreSpeedy A... Oasis 036056?001...
$10.45
PittsburghWat... Search Results
    uxcell 4.7 Ohm 1 Pin Refrigerator PTC Starter Relay Black
    www.amazon.com/...Refrigerator.../B00N3WFW5K
    Amazon.com, Inc.
    Rating: 4.8 - ‎63 reviews
    The original starting part QP2-4.7G is equivalent to this one. the 4.7G .... the PTC, so at this price, buy a spare because in year or two, you'll need another one.
    Amazon.com: Questions And Answers: Will this replace a QP
Jan 01, 2016 | Refrigerators
Danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
May 30, 2012 | Danby DWC044BLP Wine Cooler
Refrigerator not cooling ? Rridfe makinbg clicking noice ?
You did not include a model number so this is a generic response that hopefully is of some assistance. The clicking noise your hearing is the compressor cycling trying to start.
Reasons it may do this:
1. Brief power outtage of less than 5 minutes. (Unplug and wait 30 minutes if so)
2. Compressor not starting at all (causes)
a. PTC Relay failure
b. Run capacitor failure
c. Locked compressor rotor (I.e failed compressor)
d. Heated terminals or wiring problems near the compressor
A technician would do the following
1. Read terminals R & S to terminal C on the compressor (winding continuity checks)
2. Read terminals R and S to the case of the compressor (checks for internal compressor short)
3. If the above tests pass he or she would replace the PTC relay, Kilxon thermal overload & the run capacitor. If the compressor started repairs would be complete at this time. If not see step 4.
4. Perform and amperage check comparing the Locked Rotor Amperage (LRA_ amperage on the compressor label to the actual amperage reading. If it fails this test the compressor has to be replaced.
These are the basic steps for an AC voltage compressor. Should your unit have a DC compressor the steps are slightly different.
Thanks for choosing FixYa,
Kelly
Aug 15, 2011 | Daewoo Refrigerators
Compressor is short,Model FF 350.This is 350 lt.double door frost free fridge.Compresser needs to be replaced,It is bought in April 2003
If you have had recent power failures, OFTEN the PTC motor starter for the compressor gets fried. The part can cost $50 or if you shop online as low as $2. What happens is if power briefly goes off and compressor has been running, the pressure is built up and when pwoer comes right back on, the PTC starter cannot start the compressor under pressure. Usually the compressor will get hot and just hum. The PTC unit is in a box that plugs on the side of the compressor. There is a capacitor that survives this and if you reuse that, you can get just the PTC part for less than $2.
The PTC is a little disk about the size of a quarter and fourr times as thick. It comes in a plastic box that the capacitor plugs onto and the whole thing then plugs onto the compressor.
Feb 11, 2011 | Air Tools & Compressors
Refrigerator is not cooling. Compressor comes on than off after 20-30 seconds
you need to replace the ptc overload relay replaced on the compressor as this component is getting weak and is cutting out,it uses temperature vs. heat to protect the compressor from a no start or when the compressor cant operate on the run windings and overheats,then this ptc overload relay cuts out the compressor to protect it,it will keep trying to start the compressor till the ptc burns out,it just unplugs off the compressor and a new replacement plugs back in
Dec 23, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Oct 19, 2009 | Kenmore Refrigerators
Danby dkc645bls cools once, then wont kick back on when it starts getting warm.
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Oct 16, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby DWC440 Wine Cooler Logo
128 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
