Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE3 washer displays "Sud" shortly after cycle starts, then displays code F-35 shortly afterward -- and cycle stops running at that point.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
Testimonial: "this solution was completely correct; there were no hose or air dome blockages -- replacing the pressure switch corrected the problem. thanks."
My kenmore elite he3 comes on when i start it .a little water comes out than it strarts making a buzzing noise and wont stop unless i hit the pause button
DO you get a code on the from display of the machine? If it says F35 or SUD you have a water pressure sensor failure. You can but the sensor on ebay for about 54$ Its very easy in install also.
Oct 24, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore he3 the erroe code says "sud" can
SUDS LOCK (to much detergent detected during the wash cycle)
he motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked.
Dec 16, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My He3 continues to stop mid cycle. Usually I see something like SUD or a P on the screen. If I push stop/cancel and then start again usually it will eventually get through the cycle. Sometimes I have to...
The following link explains how to troubleshoot a "SUD" error on a Kenmore Elite HE3:
http://www.fixya.com/support/r3608687-sud_error
First, verify you are using the CORRECT laundry detergent. If you are, make sure you are using the correct amount (some of these detergents are double (2X) and triple (3X) concentrated.
Next, you may have an obstruction in the drain pump that is restricting water flow. Too much air detected in the draiange system can generate the error code. There is a follow-on link included that explains how to check the pump.
These are the two MOST common causes of the problem you are experiencing. If you have any questions, or have continued problems, please post back and let me know. I hope this helps you.
Jan 07, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
He3 elite kenmore- sUD and F21 error
Hello there"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Dec 25, 2009 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
