Question about Toshiba 50HM67 50" HDTV
My toshiba t.v. a 50hm67 made a loud pop noise after i turned it on today and it was on for about a min. before the noise and then it started to turn off and on then instead of the blue flashing lights they turned red and if you try to turn it on it says that it is broken, I tried unplugging it to see if it would reset but it only did the same turn off and on and then turn to red.
SOURCE: TV is not powering up and red light keeps flashing
I have the same problem on the same TV - nothing shown on screen, blinking red LED (sometimes slow, sometimes fast), clicking noise of a transformer. I got the TV free thinking I could fix it. It looks like the previous owner has replaced some resistors. Can anyone double check the pic and tell me if the mod is correct or not? PCB is marked PB9582 B Thanks
Posted on Mar 29, 2007
SOURCE: Flashing Red Power Light
i had to replace the power supply
Posted on Oct 26, 2007
SOURCE: toshiba theaterview red light blinking
new power supply
Posted on Nov 10, 2007
dwn4lf
SOURCE: toshiba 46H84 tv turned off light blinking
Sounds like a problem w/ the red tube.
Posted on Jan 07, 2008
ginko
  • 19396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
My toshiba 50hm67 has no sound
If you still have picture, and the sound was working before this--you may have lost the audio amp chip. I hope you are not running a bunch of external speakers on the tv here--this WILL kill that chip !!
Apr 08, 2014 | Toshiba 50HM67 50" HDTV
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My 50hm67 turns on for a bit then turns off or lose screen for a bit then turns back on
Some simple things to be aware of: A lamp (generic cheap) or one reaching the end of its life can cause this issue, what is age and brand of lamp in the set?
Nov 02, 2012 | Toshiba 50HM67 50" HDTV
Picture turns green after a while
need accurate model number and brand--see multiple posts here from you with different info
Apr 29, 2012 | Toshiba 50HM67 50" HDTV
Loud noise coming from ps3 after short while
sounds like youmay have something stuck in the fan or in another moving part you may want to take it apart and clean it.
Nov 29, 2009 | Audio Players & Recorders
Loud pop sound now no picture or sound error message and flashing red light
Very likely the bulb has gone they have had some issues with bulbs going quite frequently on this model, bulb I believe is about £100 and an easy job on this model
Nov 27, 2009 | Toshiba 57HM167 57" HDTV
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
I nees a cooling fan for a Toshiba 50HM67 50 inch
trucker I found this website....http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1089868%2DTOSHIBA&Show=ExtInfo hope it helps
Jun 21, 2009 | Toshiba 50HM67 50" HDTV
My TV
The loud pop was the $300 bulb exploding. Don't look for any help from Toshiba either. Their customer service stinks as bad as their product. Put the bulb in yourself and then sell to the next ****** that comes along. I made the mistake of keeping mine, because I thought that Toshiba was still a good product. Wrong, next the color wheel went out. It was back ordered forever. When I finally got one I installed it myself. So, it would only cost me the $530 price of the part with out the $400 charge for labor. Run as fast as you can. I now have vertical lines on the screen after 2 weeks. Who knows what's wrong now.
Apr 26, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 50HM67 50" HDTV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
