Question about JoWood Productions Aquanox 2: Revelation
I am having an issue trying to install AquaNox 2 on Windows 7, it starts up the installation fine, but when it gets to actually installing the content, it reads, 'Error loading W95INF32.DLL'. Then it tells me 'This program has been damaged, possibly by a bad sector of the hard drive or a virus. Please reinstall it.' Is there anything I can try to do that will fix this problem?
2 Suggested Answers
  • 122 Answers
SOURCE: Hello, i've installed the Dawnspire
Download MSVCR71.dll from dll-files.com. (It is free.)
Unzip...
Place MSVCR71.dll into C:\Windows\System32
or C:\Windows\SysWOW64 if you using a 64-bit Windows.
Posted on Jun 03, 2011
I want to play Turok Evolution on Windows 7
Works fine despite having numerous issues within the game. I have never had a problem installing it or getting it to run. I am using Windows 7 64 bit Professional. I own an actual PC copy of the game, so I am not sure where you got your version.
Mar 30, 2014 | Acclaim Turok Evolution for Windows
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Unable to install lan drivers for ame600-ur378 in win 7
Go to Device Manager and install manualy.
Open Device Manager by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, and then, under System, clicking Device Manager.
1) In Device manager, right click Network Controller.
2) Click update driver.
3) Click Browse my computer for driver software.
4) Click Browse and locate your driver, once it's done simply click Next and Windows 7 will start installing the driver.
Feb 13, 2014 | Acer Aspire M AME600-UR378 Desktop PC
Sir i installed 2 os windows xp(shows earlier installed os) and windows 7 now i want to remove windows xp which had disc error while installing it and it does not start but win 7 works fine?
it can be difficult to remove, your best trying to repair it with the same install disc first, or just forget it's there and you can manually delete the windows folders/files, removing can be tricky with dual boot unless you put it on a seperate drive then you can just format the drive it was on but backup your working OS first just in case, i had same issue and googled for long time and decided to leave it where it was in the end to avoid problems, there is a way to stop it showing up at boot up if your getting the option to boot from 2 OS but i forget how to remove this now, a quick google will show u.
Nov 23, 2013 | Computers & Internet
Windows 7 pc wont install windows updates after they have automatically downloaded
1. Did you try using Ms Fix it?
2. When did this issue start to happen?
3. The issue started happening on and what did you do: install something like software or a game.
Mar 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Can't install Rise of Nations on Windows 7 PC.
Although the disk might look fine the disk may have been inconstructed correctly i have had the same issue before ask the shop/company you have brought it from for a new copy oryour disk drive could be damages or dirty use a disk cleaner to clean out your disk reader and tray. You might have some incompatible software or you computer's might not meet the requirements to check that to.
Feb 10, 2013 | Microsoft Rise of Nations for Windows
I have an msi ms-7390 k9n sli ver 2 motherboard and I updated the bios to the latest ver. 1.2. After that when cold booting the motherboard does not initialize usb you have to press delete to enter setup...
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Jul 19, 2010 | MSI K8N Neo4-F Motherboard
JoWood Productions Aquanox 2: Revelation Logo
245 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
