Question about Sony VPD MX10 Multimedia Projector
Sony ES4 Projector :
I have a Sony ES4 projector, suddenly it stopped working.
When i power on the Projector, the LAMP/Cover light glows. & the power light is RED.
can you please inform what might be the error !!
the projector is not in warranty, as it was bought from outside the country.
Thanks in advance.
Vinod.
  • Anonymous Mar 13, 2014
    Projector can turn on, about 5 minute sudenly power off
  • 563 Answers
Hi Vinod
I would suggest you to take out the lamp and check for any damage or discolouration to it.
I'm sure that you'll find this to be the problem , in which case you will have to replace the lamp.
Posted on May 07, 2008
Sony projector xga indicate lamp cover
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 17, 2014 | Sony VPLCS1, VPLCS2, VPLCX1 Replacement...
I have a Sony projector VPL-ES4 and the ON / Standby red flashes 6 flashes. I got the lamp, I cleaned the air filter, I tried to reset Left Right Enter key and the problem still persists. Can you help?...
check a small bord under the mother bord calld air sensor
its look`s like a transistor check the divice properly and change the projector frimware through computer
Aug 16, 2012 | Sony VPL-ES4 Projector
We have sony vples4 projector ,when i turned on it ,light is glow but after 5 minitus total projetcor is turned off
Does it switch off with an error message or the lights indicating a problem. is the power saving feature switched on.
is the air filter cleaned.
Aug 20, 2011 | Sony VPL-ES4 Projector
I have a sony SVGA VPL-ES4, when i turn it on it comes on only for a little while then goes off and the power button has this continuos blinking red button. HELP please..
hi,
Do one thing try to reset the lamp hour timer. for the same do the following.
Press the following keys on the remote in the following order for less than 5 seconds each.( on standby mode)
RESET then LEFT ARROW then RIGHT ARROW then ENTER
Remember on thing lamp reset is recommended only after replacing the lamp. if works try to replace the lamp as soon as possible.
ok
Apr 28, 2011 | Sony VPL-ES4 Projector
Blinking yellow light for lamp cover and will not start up
check that the lamp cover is not bent up slightly due to old age, and the little switch underneath is activated when the cover is installed
Mar 26, 2011 | Sony VPL-ES4 Projector
How to rest lamp timer vpl-es4 - reset < > enter - doesn't seem to work
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
Apr 06, 2010 | Sony VPL-ES4 Projector
When you plug in power it indicates red but does not start the projection. The only thing i get is an orange brink from the point written lamp cover
make sure the lamp door is closed securely. if the door doesn't/ can't trigget the door switch, you'll need to replace the door, or the switch.
Dec 28, 2009 | Sony VPL-ES4 Projector
Focus Problem
the lamp of the device may be going to end its life, need replacement.
Jan 02, 2009 | Sony VPL-ES4 Projector
Sony VPD MX10 Multimedia Projector Logo
152 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
