Question about Nintendo Video Game Consoles & Games
Have a wii cant connect to internert it says error code 52302 unable to connect....what do i do?...i have a ps3 connected do i ned another router or can i use the same
  • 5 Answers
SOURCE: error 52030 in internet connections
Are you using a WEP? If so, it will only connect using KEY #1.
Posted on Nov 26, 2007
larkin71
  • 38 Answers
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Posted on Mar 08, 2008
chris252
  • 84 Answers
SOURCE: Ps3 Unable to obtain IP address and connect to internet
maybe the modem set is different from the modem in the lap top in other words maybe you ps3 needs higher and better connection
Posted on Mar 31, 2008
  • 12 Answers
SOURCE: the wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Posted on Sep 09, 2008
  • 82 Answers
SOURCE: unable to connect ps3 to cradlepoint router
Your router probably is using encryption.
If so, you will need to set up the encryption on the PS3.
Did you set up the laptop and the Wii connections or did someone else do that ?
Posted on Jun 09, 2009
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
I'm getting an Error code 51030 when I'm trying to make a wifi connection on my wii console
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected.
Jun 05, 2011 | Nintendo Wii Console
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
I have the code 220602 coming up on the wii and cant get online
Try these steps:
  • Temporarily disabling WEP encryption on the router.
  • Set up another internet connection profile on the Wii (w/o encryption key)
  • Select the User Agreement on the Wii.
  • Re-set the WEP encryption key on the router.
  • Switch back to the internet connection profile on the Wii (w/encryption).
May 02, 2011 | Computers & Internet
Up until about a week ago, our wii was connecting to the internet with no problems. No when we try to connect it gives us and error code or asking if we would like to set up internet connection. I have...
Your error code indicates that your Wii can't connect via wireless to your router. I would check to make sure your router is functioning properly and to restart it if required. I would then check to make sure that the configuration on your Wii matches that of your router. I would also check to see if any other devices can connect to your router, if so, then the wireless card on your Wii may have died and is something you will likely need serviced by Nintendo.
Apr 01, 2011 | Nintendo Wii Console
Hi having trouble getting wii on to internert
Here is a quick guide from Nintendo to help you out with your Wii's Internet connection.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineConnectNeed.jsp
Remember, when using WiFi you must be using either WEP, WPA or no security at all (not recommended) in order for your Wii to connect.
Mar 29, 2010 | Nintendo Wii Console
Unable to connect ps3 to cradlepoint router
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Cant conect to internet
  • Wii Error Code 51300 - 51399
  • This error is caused by the Wii being unable to connect to the access point.
    To solve this error :
    Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
    If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using WPA encryption, the Wii is compatible with :
    WPA - PSK(TKIP)
    WPA - PSK(AES)
    WPA2 - PSK(AES)
    If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings
Dec 27, 2008 | Computers & Internet
The wii is unable to connect to internet
Jun 12, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
100 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
