Posted on Aug 28, 2010
Hi, I'm looking for a replacement of my old ppsb0509 3.7V Li-iON battery for samsung yh-j70 digital player. Battery (does not charge) Battery size: 30x50x6mm and 970mAh. email address: [email protected] Thanks....alfred
5 Related Answers
Anonymous
  • Posted on Nov 15, 2006
SOURCE: Samsung yh-j70
did you try to change the file type of the video if you didnt you should try that use replay converter write that in file mirrors they should have it.
Anonymous
  • 5 Answers
  • Posted on Dec 08, 2007
SOURCE: cannot charge my yh-j70
When I first got my yh j70 I had the same problem. Have you made sure its in 'charge' mode? When you go to 'settings' there is an option tha allows you to switch from 'charge' mode to USB connect mode. You have to switch it depending on what you are trying to do. Hope this helps.
A
Anonymous
  • Posted on Oct 20, 2008
SOURCE: Samsung YH-J70
Keith, I have the same problem. Do you already have a solution?
regards Jeroen
MCG65
  • 18 Answers
  • Posted on Dec 31, 2008
I had the same problem - the hard drive had failed, which is a common fault. I bought a new one on eBay - a Toshiba MK3006GAL 30GB - which worked fine.
BUT... the drive came completely unformatted and I had to format it on a laptop first as I could not get it to format in the YH-J70. If the drive is FAT32 format, however, you should be OK to just put it in the YH-J70 and format it with Samsung Media Studio.
MCG65
  • 18 Answers
  • Posted on Dec 29, 2009
SOURCE: samsung digittal audio player yh-j70
All the drivers and software are still available for download on Samsung's website.
http://www.samsung.com/us/support/
Hi My battery runs down after half an hour It seems it needs a new battery, are they easy to fit? or do I need to send to Samsung. Thanks P
Yes sounds like you need a new battery. Some are soldered in, others have a wire clip that can easily be removed and replaced.
Battery goes dead right after charging
By experience I know that problem...some might suggest you to change the charge wire?I don't thing it would help.
try to reset your mp3 player or you might have to dissamble for 10 mins then close it back...
Samsung YH-J70
regards Jeroen
Samsung digittal audio player yh-j70
Do I Have the Correct Battery?? What do the mAh numbers REALLY mean?
Yes, your playtime will be reduced using the 750mAh. It won't hurt to get a larger mAh rating as long as the voltage is the same. Of couse it needs to fit.
5helpful
Cannot charge my yh-j70
2answers
Error message
Did you try pushing the reset button and/or reinstalling the software? sometimes that helps. Also, I have a question for you: I am thinking of replacing the battery on my yh-j70, as it is getting weak, was it easy for you to open the player and can you then simply pull out the battery or do you have to solder? Would you happen to know where batteries can be bought for this unit? Thank you
 Grubhead
Grubhead
SmartAviator
SmartAviator
