Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Mower was working fine and I needed to back up and the mower would not go into reverse. II continued to mow and it was doing fine as long as it was in a forward gear for about an hour then all of a sudden it guit pulling and wouldn''t go into any gear.
  • 2,382 Answers
Hi, this is how to trouble shoot your mower when it doesn't engage in gear....
If you physically can not move the gear shift lever into gear, it could be a problem with the shifter linkage or the transmission. If you can select a gear by moving the the lever which is attached directly to the transmission, it is the linkage. If the lever moves into a gear but the mower doesn't move, it could be a broken belt or a bad transmission.
Posted on Aug 28, 2010
How do I make my Troy Bilt Colt XP zero turn mower mow in reverse
it may have a separate setting with the key. mine after starting you turn the key back one notch and it will let you mow in reverse. hope this helps.
Apr 24, 2016 | Troy Garden
Troy bilt mower pony
are your blades engaged when you try to do this??
if so it is a back up safety feature from factory,turn blades off and try?
Or put the ignition switch in the position that will keep the mower running when you go in reverse with the blades on or push a button on dash when you go in reverse,probably not on yours just some of the features on some models and just something to look for on yours
Aug 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
My 1147 mower blades shut off every time I have to go into reverse. After mowing for 45 minutes, something must heat up because I can't get the blades to come back on. There is a problem that could be...
As for the blades shutting offf when you go in reverse, it should have a reverse mow safety switch. Some mowers have them, some do not. In regards to the electric PTO switch, and you would have to take electical measurement when it happens, the coil in the electic PTO clutch may be starting to go bad.
Sep 22, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
122 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
