Question about Ryobi Multi-Volt Battery Charger
My batteries are not taking a charge - yet the charger is displaying that they are charged. How do i fix it?
  • 90 Answers
I would check the output voltage of the charger with a volt ohm meter. if the charger output is ok then there is something about the batteries that won't let them take a charge. the batteries that you can work on is not really worth it. by the time you purchase the parts and if it works you don't save much money.
Posted on Sep 01, 2010
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
I just bought some nyko duel charger batteries with a charger the battries have chared for days and wont charge past 2 bars whats goin on with them how do i fully charge them
This sounds like an issue with the batteries themselves. If they are brand new i would suggest possibly taking them back to the store you got them. If they are past the return time frame then look into the manufacturer warranty.
Aug 18, 2011 | Microsoft Video Game Consoles & Games
Casio Exelim EX-Z77 battery will not charge, charger light flashes on and off.
Your battery maybe drained, you can try to leave it in charger for hours( it will take long for a drained batt to start charging) blinking led may indicate that charger is trying to supply current to batt, anyways I strongly suggest you to buy a new one
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
My razr does not charge
when your phone doesn't charge,three things might be the problem,namely;the charger,the charging port of the phone or the battery.to be sure its not your charger,try using the charger to charge another phone of its kind,if it charges another phone then you can be sure the charger is not the problem,but if it doesn't,it means the charger needs replacement.
you can insert the battery in another phone and charge to know if the battery is the problem,if it charges then you can conclude the fault is not from your battery and the charger but rather the charging port of your phone is bad,you'll need to take it to a qualified technician to help you fix it
Feb 28, 2010 | Motorola Mobility RAZR V3
Got a new blackberry pearl will not charge is it
Try a different charger (like your car charger instead of your home charger) - make sure while it's plugged in - the display shows that the charger is charging it, blinking - or bars going up or down, or a thunderbolt on the display screen next to the battery power symbol etc
Once you know your charger is working, its probably easiest to find someone else with a BB and ask them if you can trade them batteries for a day to see if it's a bad battery. ( You can usually buy a battery for $5 on ebay, or up to $20 in a cell phone store)
All in all, trade someone for their battery, or their charger - if you dont wanna buy one at first. See if the problem follows your old battery etc..
And if neither solve your problem then its the BB itself. I have called in to the cell company before and let them know we have a BB that will not hold a charge no matter what battery or charger I use... and they usually replace it under warranty as long as its less than 12 months old, and the white squares in the battery compartment are still white.
Dec 31, 2009 | RIM BlackBerry Pearl 8100
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Charging
not charging
Oct 04, 2006 | Nokia 1100
Ryobi Multi-Volt Battery Charger Logo
131 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
