Question about Malber TD700 Electric Dryer
The door mechanism for the dryer appears to have been burnt out. Where can I buy the piece?
Door handle broke .
Posted on Feb 12, 2011
  • Malber Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
Dyer wont stop when door opened
there is a switch on the door this would be my first place to check the mechanism that pushes on the switch may be broken and locking the actual switch in the closed position or the switch itself. this should be a simple fix. you may be able to bend mechanism back into correct shape or you may need to buy a new switch to replace the one on door
Sep 15, 2014 | Whirlpool Dryers
Burnt factory-placed fabric/foam inside Kenmore Dryer
Why it'd appears to be scorched I have no idea. The purpose of that fabric is to support the front of your drum and allow a non abrasive surface for the weight of drum and cloathing to slide on during use. The cloth you have in yours has been changed to silicone or other types of teflon type surfaces. John T.
Mar 02, 2013 | Dryers
Dryer will not turn on.. plug is working, no burnt wires no problem with door, fuse in breake panel ok
remove the back, you will see a thermal fuse along the inside back panel,, usually a little white piece of plastic with a wire on each end,, replace it
May 26, 2011 | Kenmore Dryers
Dryer drum lamp burnt out. displays now flash. dryer wont start. is there a connection?
connection between your lamp not working might be due to your door switch that is not working test the door switch see i it makes a clicking sound when u depress it if it doesnt make clicking sound theres your problem if it does then your in for some easy testing of rune fuse and to relays one is a hi other is a low allthree of these should be checked or continuity if any of these three pieces do not have continuity then that wouldbe te one that you would replace hope this helps
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
How do you repalce a door latch on a Maytag Model 512 Dryer?
You should be able to pry out both the male and female piece with a thin blade screwdriver or putty knife. Don't worry if you break either piece. You should end up with two holes. one in door and one in front panel. Buy kit and pop in both new pieces.
You may want to buy the kit first (part number 306436)...it will show you the construction of the two pieces before you begin prying.
Good Luck
Sep 27, 2009 | Maytag Dryers
Motor's burnt out!
maytag was purchased by whirlpool and there could be something in the blower housing causing the motor to drag the maytag dryer generally has a pretty good standing in my daily repairs it seem most of our modern unit are having some issues good luck
Sep 03, 2009 | Maytag Neptune MDG9700A Gas Dryer
Whirlpool dryer wont start
Check the door switch actuator (the piece sticking down that the door actuates when closing . Could have broken off . If there , and you hear a click , then thermal fus (white piece with 2 wires attached ) could be problem . Disconnect power and put the 2 wires togather. Reconnect power and see if dryer starts . I have never had to replace a push-to-start switch .
Jul 14, 2009 | Whirlpool Dryers
Whirlpool Gold Ultimate Care II Electric Dryer
Hi, there sould be a two piece door catch. One piece on the door and another on the front panel that the door closes to. Look at the piece on the door. You will probably find it is bad. You can buy just that piece and change it. I hope this helps. If I can assist you further please let me know.
Thanks
Vic
May 13, 2009 | LG DLG2524 Gas Dryer
Power/Switch & Heating Fault
There is a switch inside or near your timer. Take off the top back panel and look for switch. If don't see one, it's inside the timer. Spray contact cleaner inside the timer. Keever
Mar 05, 2008 | Dryers
Malber TD700 Electric Dryer Logo
158 people viewed this question
Top Malber Dryers Experts
Charles T Nevin
Charles T Nevin
Tim Whalen
ray gallant
Are you a Malber Dryer Expert? Answer questions, earn points and help others
