Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
DD603: My original problem was an F2 error. The rotor assembly was very stiff and felt gritty when I moved the blades. Since the rotor assembly was frozen in the motor, I replaced both. Now I get a constant flashing of the LED display that I can't turn off, so I can't even get to the other diagnostics. The other drawer works fine. My next thought is to change out the controller with the one from the working unit to see if that is the problem.
  • 1 more comment
  • RussColorado Aug 28, 2010
    Clean miss! As I posted, I just replaced the rotor assembly and motor. Try again
    F2 means that your rotor is jammed. If you open the drawer and remove the dishrack, you can pull straight up to remove the wash arm. There is a plastic locking ring in the center of the silver filter plate. Twist this 1/4 turn counter-clockwise and pull the filter up and out. Next is the rotor, turn the rotor 1/4 turn counter-clockwise as well and replace this part because it's not functioning correctly (assuming you don't see something blocking the rotor from moving that you can just remove).
  • 10,515 Answers
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 28, 2010
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
I have a DD603ss Fisher Paykel Dishwasher that will not complete it cycle and stops with a beeping sound and a faucet symbol on the display. The washer itself has hot water in it that will not drain. ...
Solution
This is telling you that you have a leak ,the sensor is in the bottom of the unit under the drawer, your best bet is to call for service. This unit has to be pulled out and disassembled unless you have some one that is very handy!!
Originally the dishwasher ran for a minute and came up with an F2 message. I removed the basket, blade, and blue component (not sure what it is called) I cleaned them and ensured that the all moved freely but have only placed the blue component back in. The unit progressed more into the cycle but has the above problem referenced above.
Solution
Below is the link to order the same :-
https://www.fisherpaykelparts.net/product/525884P/525884P-Motor-Rotor/
There is a probability that if all of these error message's are there, there is a problem with circuit board. A problem with them could cause multiple error message or displays on the screen, even though there is no such issues. So, this problem has to be collectively inspected and checked before you could order any parts.
Hope i helped you.
Jan 09, 2011 | Dishwashers
Bottom draw want wash this machine has been in storage
F2 indicates motor problem.
I hope you have the user manual.
If not get it from
http://dl.owneriq.net/9/95870094-43e8-493a-96bc-7f786df76d53.pdf
Go to page 21 (cleaning filter plate).
There must be something (a seed or piece of bone) stuck in the rotor chamber. Take the rotor out (impeller) and clean the chamber. Also under there is a small channel between the drain sump and the rotor chamber. Use a stiff thin wire and clean it.
Hopefully the rotor is intact. Replace everything and you should be all right.
Post me a message if the rotor assembly appears cracked. Then you need a new one.
May 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher and Paykel flashed a F2 error code. What does it mean and what can be done to clear it.
F2 error means motor problem. This could be due to several reasons. The most common is grime going in from the drain filter and getting stuck around the motor rotor cavity.
Follow instructions in your user guide to clean the filter plate. At this point you can take the rotor out and clean the cavity. The rotor can be pulled out carefully without pressing too hard on the impellers.
If this does not help then try cleaning the connecting link between the drain filter and motor cavity. You will need a thin stiff wire for this.
Finally if nothing works, the rotor might be broken and needs replacing.
Nov 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I am getting an F2 error code on an DD603.
there is something jamming in the rotor , lift the spray arm and try spinning the blue fan , or if u havent used the btm drawer in ages it is a seized rotor , around 80 $ to buy new
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer model DD603 gives fault F2 (Motor). Unit has only been used a few times. What to do? Out of warranty.
Ok this is what you do you need to swap over the motor rotors from top drawer to bottom drawer. check for anything jammming the rotor etc when you take it out. if it works with the other drawers rotor then you need a new motor rotor. cheers
PLEASE GIVE ME FEEDBACK
Mar 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel
Looks like another older post unanswered, but for the sake of info I will answer it anyway.
F2 is a "motor not sensed to be rotating" code. This can be a simple as the rotor not being seated in the base properly, or it can mean you need a new rotor part number 525884P. Sometimes the impeller locks up or there is an object caught in it. You can remove the wash arm and filter plate with no tools, and then twist the base of the rotor assembly counter-clockwise and lift it right out. Try and spin it by hand. If it is frozen, it will need to be replaced.
As I said, no tools needed. You can get them here:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
Oct 28, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
120 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
