I have a sony trinitron 32'' and i hear a popping noise from time to time and the picture goes in and out
  • spicemike Aug 29, 2010
    i am hearing a popping noise from my sony trinitron 32' is it even worth fixing
  • Televison & ... Master
  • 17,130 Answers
Look into the back side and it is possible that the leak is from the flyback transformer, a spark is just jumping around.
switch off and clean the static dust from the LOPT , clean the neck of the picture tube , use some silicon insulation to the area of leak noticed.
Now switch on to test.if the same noise comes on it can be that the power is switching off and the poping sound can be from the speakers.
Look into the power supply, main board fro dry soldering joints. clean and resolder all such suspected joints, tap around to confirm the presence of loose connection.
Be very careful when checking the set powered on.
Posted on Aug 29, 2010
  • 10,515 Answers
If picture goes in and out and you could hear a popping noise, more likely it is a problem with power supply board.If you have some experience in electronics, you could open the TV and pull out power supply board. On that board, you would find blown / leaked / bulged caps.You need to pull them. Go to radioshack and buy similar caps. Solder the new caps and it would be all set.
If that would not solve the problem, revert and we would troubleshoot further.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 28, 2010
  • taran_2005
    taran_2005 Aug 30, 2010
    Thanks for your response!!
    If you could repair it yourself, it would be worth repair. You need to check certain IC's on the power supply board. Unless, the thumb rule ' If the cost of the repair is more than half the amount of the product, it is better to go for a new product '.The cost would be high to get this repaired from a technician.
    Hope i helped you.
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega kv-32xbr400
My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
50"sony wega
Dont plug it on your tv the FLYBACK of your tv was defective. Need to replace your flyback or else more parts inside was damage. Bring your tv to a Electronic tech.
Jan 01, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
TV went out
When you press POWER can you hear a click at all ? If not, it is likely some transistors in the relay circuit got damaged. Usually Q605 and Q691 short out. I fixed this same problem several times. Good luck.
Dec 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega 32"TV - noise on startup
The slight flash on the screen is usually because the CRT (picture tube) is holding a better than average charge and this is what we call "pre-glow" The noise that you hear, is that everytime you turn it on or just after it has been off for a while? If only after the set has been sitting off for a while then your noise is the internal degauser for the CRT and that noise is 100% normal. The degausers in Sony TV's are so strong they usually make the plastic cabinet vibrate a bit.
Apr 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
