Question about Refrigerators
MY REFRIGERATOR STILL WORK, BUT ONLY THE TOP, THE FRESH AIR DOESN'T GO TO THE BOTTOM. I THINK ITS BECAUSE OF THE FAN. IT STOPPED WORKING. PLEASE HELP.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Freezer ok, fridge not cooling
That could be the motor up in the freezer is not working or it could be a defrost problem. If you see frost on the back side of the freezer that is most likely a failed defrost circuit. If you cannot hear the fan motor or possibly a fan switch mounted in the door jamb. Sometimes the drain can stop p and water puddles between the top and fresh food bottom. Forms a slab of ice and blocks the cold air from getting to the fresh food section.
Jul 28, 2011 | Kenmore Top Freezer Refrigerator
BOTTOM FREEZER WORKS FINE. Refrigerator part is not cold even though we turned it up to #7(high) setting. Vents under crisper drawers are clear, no problem w/ seal on the door. Cowling at top houses the...
You have a defrost problem. The refrigerator gets cold from air circulated from the freezer coil by a fan.
If the coil has ice on it due to improper defrost, then this air is restricted.
Dec 20, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The bottom refrigerator don"t get cold. water was leapin on bottom shelf be fore it stop working. Thank you
Look for frost build up on the back panel in the freezer side. If there is then you'll need a defrost timer or heater. Also check to see if you can hear the fan running in the freezer, if not that's your problem...replace it. All the cold air comes from the freezer it needs the fan to get it to the fresh food side.
Oct 20, 2010 | Frigidaire FRT15B3A Top Freezer...
The freezer works properly but the lower part doesn't cool would you please help me
Set the freezer control to Warmest.(more air will go to fresh food)
Make sure the freezer fan is blowing.
Check the door seals on fresh food door especially on the bottom.(may be loose letting in warm air)
Aug 10, 2010 | Magic Chef CTB1821AR Top Freezer...
All of a sudden, my refrigerator doesn't keep anything cold like it used to but the freezer still works. We have cleaned underneath but it still doesn't keep anything cold. What could be the problem?
Look for signs of frost on the back side. You probably have a defrost problem of it could be a drain problem.
Your ice box cold air originates in the freezer. A fan pushes down the cold air into the fresh food section. If their are too many items in the freezer the air can be blocked to the fresh food section. If the drain stops up sometimes a puddle forms a slab of ice between the freezer and the bottom. I ave an apartment maintenence man's guide to these ice box's for you HERE. It feature 4 differnt styles of whirlpool ice box's in your size.
May 25, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Freezer works but the refrigerator doesn't
Check to se if you can hear or feel the inside fan running while the compressor is also running. I don't think it will be due to this is most likely your problem. What cools your fresh food section of your fridge is air from the freezer. A fan pushes air from the freezer into the fresh food section. This being said, I think you have a bad fan motor of something is not letting it turn.
Please rate solution.
Aug 28, 2009 | Dometic RM2652 Refrigerator
My Jenn Air bottom freezer refrigerator is too warm in the fresh food (upper) compartment. This just occurred today. The freezer works fine. Any ideas?
sounds like the FF(Freezer Fan) is starting to wear out. This fan problem is very hard to diagnose because the fan will still spin but not fast enough to circulate chilled air thru the freezer as well as the refrigerator.
Jul 30, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
