Question about Acer Aspire 5600 Series 5630-6951 Laptop
Operating System is not detecting in my Laptop
Hi.. my laptop is NOT recognising harddisk drive when i'm installing new windows xp from bootable cd since windows os is corrupted.. when i start installing, it wil copy files but in later step( i.e selection of Drive C or other) it wil display "Cannot Access Harddisk" . so plz guide to solve this problem.. n is it a BIOS setup option problem? shall i change it? r is it a Hardware problem? plzzzzzz Assist me as early as possible.
  • 655 Answers
Kiran,
Windows XP not able to access SATA hard drive without driver. So it will not recognize your HDD if its of SATA interface.
  • If you can enter in BIOS setup, find out SATA option and if you find make it disable. Then try to install.
There are also other ways to fix this problem, if you want more help Just ask me.
Thanks
Iqbal
Posted on May 07, 2008
I have bought a new asus laptop and it has no operating system installed. I have purchased a separated os installation disc..how can I install my os on my new asus???
Hi !
I have a blog on how to install Windows XP operating system and it is just the same with other operating system like windows vista and windows 7. Here is the link http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean.
I hope it helps you. Good Luck and thank you for using FixYa !
Jan 07, 2011 | ASUS Computers & Internet
How to format my compaq pressario cq40 604tx laptop with xp
hi
Boot from your XP install CD and select the option to format the C:
drive. If you don't have an install CD, use the "System Restore" CD or
DVD that came with your system. These restore your system to factory
settings. There're still other ways to format your C: drive, but
without either an install CD or restore one, you'll end up with an
unusable system after formatting the C: drive.
If you use the XP install CD, you'll need to be SURE you have all the
drivers for things like your DVD/CD drive, NIC, video, audio, modem, etc.
Jul 02, 2010 | Microsoft Windows XP Professional With...
Problem booting into xp home edition on laptop!
Hi Andrew,
Before you install XP check the memory, harddrive, cddrive is getting detected in CMOS or not. What about the data in your harddrive?
connect the harddrive to another PC and copy the Data from the drive. If not you will lose all the data on the harddisk if you install the XP on the same disk.
If you had mentioned the system configuration, i would have told whether you can install XP or Not. Since its a laptop and just 5 years old i guess you can install XP on that.
Raj
Jan 13, 2010 | Computers & Internet
I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
Nov 25, 2009 | HP Pavilion dv5-1140us Notebook PC
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
http://en.kioskea.net/forum/affich-39282-xp-can-t-recognize-hard-drive-for-os-install
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Remove vista and install XP on HCL laptop
Your laptop probably has SATA hard disk installed in it. You will need to install from an XP SP2 or later CD for native SATA support. Otherwise you will need to get the SATA drivers for the chipset being used on the laptop and slipstream them onto a new bootable CD or go through the process of adding the drivers manually during the initial phase of the installation.
Apr 07, 2009 | Microsoft Windows XP Professional With...
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
