Question about Frigidaire FAC125P1A Window Air Conditioner
Window ac has sweet smell - Frigidaire FAC125P1A Window Air Conditioner
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Water on passenger side floor
This could be a sign the heater core or hose has gone bad and is leaking into the cabin since it is located inside the dash ifs its antifreeze it will have a sweet smell.
It could also be your AC condenser, or possible window seal.
Jul 14, 2012 | 2008 Kia Optima
THE PASSENGER SIDE FLOR IS SOAKED IN MY 2002 XG350. IT HAS BEENTHIS WAY FOR A WHILE. I AM TRYING TO FIND OUT WHERE THE AC DRAIN IS TO SEE IF IT IS CLOGGED
Is the water on the floor sweet smelling? If it is then you may have a leaking heater core. They've been known to leak onto the floor. Antifreeze usually has a sweet smell to it so you should be able to tell that way. Your A/C should just drip condensation outside the vehicle but I wouldn't think that it would be enough to soak your floor constantly. Hope this helps
Sep 11, 2010 | 2002 Hyundai XG350
My 1996 pontiac grand am is leaking water from under the car by the front passenger wheel. What would be wrong with my car
Is it water or is it engine coolant? Does it smell sweet ... have a color to it ... probably engine coolant. If it is clear water with no smell, it is probably AC condensate. Typically, this is where condensate drips, as the AC is located on the passenger side.
Thanks for your interest in FixYa.com
Aug 12, 2010 | 1996 Pontiac Grand Am
Smoke and it smells comes out of vents when ac on nissan altima
Smoke from under the hood ?
Smells like burnt rubber ?
Either the compressor or the comtressor clutch is bad so it locks up wen you urn it on and the fan belt is burning..
have the ac system inspected..
Aug 20, 2009 | 1998 Nissan Altima
O2 tahoe
Probably not. Residue on the passengers side rug is likely either from a leaky heater core or a blocked air conditioner evaporator drain. Is the residue slippery feeling? Does it have a sweet anti-freeze smell? If you blot it up with a white towel, does it have a color?
If it is colored the same color as your anti-freeze (green, orange or pink, depending on what type your tahoe uses) and has a sweet smell, my bet is the heater core is leaking. This would also cause fogging on the windshield when using the front defroster and a sweet smell from the air vents when the heat is turned on.
If it just seems like water and seems to get worse when you use your air conditioning, it is likely a blocked AC evaporator drain.
In any case, neither of these problems are likely to be related to an intake manifold job.
May 28, 2009 | 2002 Chevrolet Tahoe
Leak under car
if it's water, and not gas it's not your fuel pump. if it's water and not a sweet smelling green or red liquid it's not your cooling system. it's probally condensation from your ac, have you been using your ac alot? if so no worries. or a bad window or door seal and it's letting in water onto your floor. and yous aid under the door, so it's on the ground or on the floor of the vechile? if on the ground, more then likely it's just your weep drain from your ac system.
Mar 14, 2009 | 2000 Kia Sportage
My car was drenched on carpet in front pass side what could it be
sweet smell, green or orange color, low on engine coolant, then it would be your heater core. Regular water, been using ac alot, weep drain clogged.
Sep 13, 2008 | 1997 GMC Jimmy
AC-Smells
that job I haven't done yet. the smell you are getting is it a real sweet smell? If it is possible antifreeze leak. Beyond that I;m not really sure. Unless someone poured something down into the cowl vent. Do you get the smell when the ac is on with vents open or recirculator button pushed?
Jun 10, 2008 | 2004 Suzuki Forenza
Heating & Cooling Logo
682 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
