Question about Curtis-Mathis Televison & Video
I HAVE A CURTIS MATHES TV MODEL FC2751LC CONSOLE COLOR TV AND THE PICTURE IS NOT STILL. IT IS CONSTANTLY MOVING. HOW DO I FIX THE PROBLEM
  • Curtis-Mathis Master
  • 11,800 Answers
The image is moving because the vertical deflection module isn't synchronized with the vertical syncro burst from the tv signal. Most likely all you have to do is to adjust the vertical syncro resistor , it should be accessible and with a button at the back of the tv. If the button is not there you will have to take the back cover off and look for it -  it will be a clearly labeled semi-adjustable resistor.
Posted on Aug 28, 2010
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
How do I change a Curtis Mathes Analogue to Digital
You can't. The only way to change it would be to go and buy a new TV. Unless you're asking about hook a game console to it, that's a different procedure. The analog refers to the internal workings of the TV its self.
Nov 07, 2014 | Televison & Video
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Adjusting curtis mathes projection tv model fp4600ek02
If this tv is more than 10 years old, I would say the three projection tubes are getting weak.
This may be a good time to invest in a new tv.
considering the difficulty of obtaining parts for it and the other problems you could have in the near future, it would be cheaper to replace the tv.
If the tv is not that old, please let me know the model number for more assistance.
Jun 29, 2008 | Televison & Video
Curtis Mathes 27" TV
better to replace a/v jacks as you have already soldered it
the problem is due to jack only.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
