Question about Peg Perego John Deere Gator HPX Ride on Toy
The gator was running and just stopped. I checked all the wiring and recharged the battery. It will not go in any gear. I also checked the fuse.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 13, 2012
5 Suggested Answers
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: I'am Looking for a diagram for a Plunger Fuse onthe gator 4x2
The wire sequence is red, white, blue.
The red is the farthest from the other two.
If it is a peg perego switch plunger style then this will work.
Hope this helps
Posted on Jun 23, 2009
Samir3050
  • 70 Answers
SOURCE: My kids gator just stopped
it could be the gear switch, try calling the tech support and they are very good at leading you to the right results
Posted on Mar 01, 2011
Samir3050
  • 70 Answers
SOURCE: gator wont go
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Posted on Mar 02, 2011
My child's gator just stopped working. She got on it, it went slow in both gears then, no reverse or 1ST, NOW NOTHING AT ALL. PLEASE HELP. All wires look good.
Jamie, sounds like a bad battery, try and recharge battery. You may have to find a small electronics shop to check battery and charger to verify if they are any good.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 13, 2016 | Toys
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
My kids gator just stopped running. Battery is good, but tried on different battery with same results. Any suggestions?
Feb 27, 2011 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator just stopped running at all
first of all check the battery and the charger and make sure that they are putting out at least 12 volts
Aug 27, 2009 | Peg Perego John Deere Gator HPX
Peg Perego John Deere Gator HPX Ride on Toy Logo
48 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
