Question about Kenmore 62622 Microwave Oven
Light bulb needs to be replaced for Kenmore microwave model #721.62649200. Can I do this myself? I do not have the owners manuel anymore so not sure how to get to lightbulb. Thanks for your help.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 102,366 Answers
Http://www.managemylife.com/mmh/owner_manuals/11148/
KENMORE-Microwave-Hood-Combo-L0310032?brand_name_search=62649200
Posted on Apr 27, 2011
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Kenmore Microwave, overhead household, Model 721-6264900
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Microwave 721.66319 500 Light buld gone out - now what?
First of all, since this will involve disassembly, we have *critical* safety & disassembly info at our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams for your Kenmore model here: http://www.searspartsdirect.com
Enter your model number as 721.66319500.
The light bulb is shown in the "LATCH BOARD PARTS" diagram and it's located in the area of the door switches.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
It's best not to touch the bulb with bare skin, as the oils can shorten thee bulb's life. And I recommend a high quality bulb from places like Home Depot, instead of cheap types from the grocery store.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 30, 2008 | Kenmore 63252 Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
197 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
