Question about Sub-Zero 695/O Side by Side Refrigerator
The refrigerator side working fine,stays stays at constant 36 degrees. frezeer side wont go below 16 degrees and rises to 20's as soon as opened.
  • Sub-Zero Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Refrigerator FGHX2644KF2, THE FREEZER IS NOT COOLING OFF. I HAD A SMALL CHILD TURN OFF THE FREEZER AT THE CONTROLS, BUT DID NOT CATCH IT FOR ABOUT AN 30 MINUTES, when I turned it back on the temp said...
is it staying at 16?? a freezer thats attached to a refrigerator would be considered fully functional about id say 30 degrees and below, As long as it stays under 32 I wouldnt worry about it, you can always try unplugging it for a few minutes if you want, but as long as temp stays at 16 or lower than 32, its fine............. a deep freezer are the ones that usually get alot colder than 32, but generally only because thats the systems only job, its not also running a refrigerator.
Nov 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
My freezer will not get below 20 degrees at the coldest setting. Why is this?
Here is the factory service manual.
cut and paste this pdf link.
http://136.166.4.200/contents/Fridge/LRSC26922xx/LRSC26922xx_Service_Manual.pdf
Check for ice on the freezer coils.
Check the Freezer fan motor.
Check the Compressor fan motor.
Jul 24, 2010 | LG LRSC26940ST 36" Side-by-Side...
My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Mar 12, 2010 | GE CleanSteel GSL25JFTBS
Amana bottom freezer refrig runs at maximum coolness
Thanks for your inquiry. I think I may have fixed it. I unpluged it and took everything out of the refrigerator and freezer, cleaned it thoroughly inside and out and unscrewed the back wall inside the freezer. There was a huge ice buildup on the coils so I let it sit for 12 hours like a defrost. I turned it back on and it seems to be working fine. It is not running constantly and is maintaining about 5 degrees below. If this doesn't stay working, I guess I have to call a repairman.
Feb 14, 2009 | Amana ABB1927DE Bottom Freezer...
Correct Temp
frezeer 0% to 5 refrigerator section 36 to 38
Oct 31, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator interior heating upwards of 90 degrees/freezer seems fine
is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Oct 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
I am currently experiencing the same problem. It happen when I pressed the rapid cool button on the inside of the fridge and the temperature went down to 36 degree F. I assume that my water line is frozen. As soon as we use up some of the food in the fridge, I'm going to clean out the fridge and let the temperature rise, hopefully thawing the blockage. This is the only thing that I can think of.
Mar 25, 2008 | Refrigerators
Sub-Zero 695/O Side by Side Refrigerator Logo
59 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
