Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
Lens stuck out, cant switch off/on. - Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Despite my samsung L50 camera being fully charged I cant get it to switch on. The blue light flicks on then dies away again with a bleeping noise. I can however view previously taken photos by pressing the...
Here is a website that lists the things to do and check to try to fix this problem:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Mostly this consists of ensuring that the battery is good, and holding a full charge, and also making sure the battery contacts are clean, both on the battery and inside the camera.
As a last thing to check, the switch could be bad. The next web blog talks about another problem the camera could be having, which is a lens "stuck" issue:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though it says lens error, it still apllies to stuck lens.
Good luck, and hope this helps.
Oct 31, 2010 | Samsung Digimax L50 Digital Camera
Lens is stuck
If the camera was bumped and the lens is stuck for that reason you will need a repair that is not covered by the warranty. If the camera has a defect and it is less than a year old and bought in the USA you can send it off for warranty repair. Take it to you local camera store for them to help.
Nov 18, 2009 | Cameras
Nikkor Lens Cannot Manual Focus
It sounds like you had the lens set for manual focus when you took the A / M switch plate off. If this was the case then when you but it back together the little arm behind the plate is on the wrong side of a moving gear assembly.
To fix, remove the auto/manual focus switch plate from the camera (just the one screw not the ribbon beneath) Push the switch over to A. Hook the bottom of the plate back to the lens and put the screw back in. Done!
Jul 26, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Lens problem
The lens mechanism would seem to be damaged in some way.
There is normally no repair solution with this sort of thing because of the fine mechanism involved.
If you have someone you know who can work with fine instruments to take it to pieces.let them try.
I guess as no repair option is available you cant make it worse by trying to find out
Otherwise - new camera
Jan 16, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Error code E45
can u help me with my camera. its a kodak LS 443. I keep getting a saying that is has a error # E45. the lens are stuck. Can u tell me wat do do or give me advice please
Nov 20, 2007 | Kodak EasyShare LS443 Digital Camera
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
