Question about KitchenAid Kitchen Ranges
Kitchenaid range 1996 Mod.#KGST307BBL2 All four stove igniters continually igniting, unpluged range, pluged back in- same result. Also, previously to this problem igniters for stove worked inconsistently.
  • 4,323 Answers
Hi
Please check the electrode whether it is clean and the holes of the burner are clean. Electrode is the small piece that is from where the sparks comes off. Use a pin or paper clip to clean out the burner holes, don’t use the tooth picks as they might get stuck and break.
Now check for the ignition switches under the surface control knobs, the switches can break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If everything looks fine then you may have a bad spark module. It may also have happened that the switches or the range control knobs have got wet and are causing the spark module to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area. Let the area dry completely and check. If this doesn’t resolve the issue then you would need to replace the ignition switch/spark module. Please check the schematic below---
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 28, 2010
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
Burners continuously clicking
The most common cause of this complaint is from liquids getting into the internal igniter switches or igniter wiring for the range and shorting them out. This happens many times when someone cleans a range with liquid cleaners or a pot of water boils over. The fix to this is to unplug the range for 24 to 48 hours to allow the liquid to dry out. Sometimes you can speed this drying process up with a hair dryer. Remove the burner knobs and point the dryer into each burner knob stem to get the heat in there and dry out the switches. Once the liquid has dried then you should be able to plug the range back in and it will work like normal. If you leave it plugged in the excessive use of the ignition system can short out the coil. The second thing it can be is a defective ignition switch. Each burner knob has an ignition switch built into it. If one of those swithces gets stuck in the closed position then this can cause the ignitioin system to continously run. The fix for that is to replace the switch.
Apr 17, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
The dial on my maytag gas stove shorted out
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Nov 30, 2008 | Maytag MGR5765QDS Stainless Steel Gas...
Dcs range igniter
Our GE range Profile, the igniter continues to spark with it on off. All four burners igniter contiues to spark. We have it unpluged at the moment, but it seems like it needs to reset or something. Will it stop when we plug it back in? I am not at home is why I ask this question, or I would plug it is an find out. Any help?
Aug 18, 2008 | Kitchen Ranges
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Ignitor maytag MGR6772BDS gas stove
One of your switches on the gas controls is bad. You'll have to remove the lines from the switches to the ignitor one at a time to figure out which. With the power off, lift the top of the range to expose the controls. There are connectors for the power at each control. After removing one line, turn the power back on and see the result. You'll know when you've hit the right switch. Then, replace it.
Dec 14, 2007 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
Kitchen Ranges Logo
143 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
