Question about Whirlpool LGR5636L Gas Dryer
Dryer doesn,t dry every load. only works sometimes, what could be the problem??
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My dryer takes about 3 hours to dry one load, wer changed the coils, gut the problem is still the same, what else can it be?
Check to make sure the vent is not plugged with lint. Also wash your lint screen make sure it doesn't hold water sometimes they get a film on it and it won't let air by. Quick way to check your vent if you can't get to it........ Is to buy another flex pipe and run it outside and then dry a load of clothes and see how long it takes...
Jun 10, 2011 | GE Dryers
The dry sensor cycle will stop after 3 min... I tried big loads, small loads, normal loads and it seems the sensor doesn't work...
Try checking the dryer vent to be sure it is not clogged or partially blocked with lint. You may have to replace the sensor if all else is well
May 15, 2011 | Samsung Dryers
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
Not drying all the time. Sometimes it works sometimes it doesn't. Seems to work for about 15-20 minutes than the heat goes off
Remove the connecting vent on the rear of the dryer and dry a load. If it dries correctly find and repair the vent blockage.
Jan 01, 2010 | Kenmore Dryers
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Sensor not working correctly
using a scotchbrite padon the sensor will do better than cleaner, its dirty from build up of dryer sheets
Feb 11, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LGR5636L Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
