Question about Microsoft Office Professional 2007 Full Version for PC
Disable the print
I want to lock or disable the printing option of 1 documents?
is these possible?
if yes HOW?
  • Anonymous May 07, 2008
    M S office 2007 diseble printer
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Click the MS Office button, Prepare, and then choose the security option you desire (disable print, for example). This feature is not available in all versions of Word - but it is included in Ultimate, Professional Plus, and Enterprise. If you have another version, this is not in the security options, but if your product is one of these three, you should be able to handle easily as indicated. Thanks for rating FixYa!
Posted on May 08, 2008
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
I'm getting the message 'cannot continue to print as disk is full' How do I clear the internal memory?
Hi Lucy,
Try this:
Your print job is killing the printer's memory. a couple things to try:
1. disable spooling and print directly to the printer.
this almost never works, but from the control panel, open printers (and faxes) and right click on your printer and select "properties". the radio button to check is under the advanced tab.
2. print to an image first, print to another software printer, like the microsoft document imaging printer. then reprint from the .mdi file that is generated by it.
3. export your file to a non-publisher document.
file save as file type to something other than a .pub file. a .doc might work, then again it might muck up your layout.
a .jpg/bmp would work very nicely for printing.
4. increase the memory to your printer.
this option may not be possible for you.
Sep 21, 2015 | Canon imagePROGRAF IPF710 Printer
How to enable advanced printing features
possible you have to uninstall the printer and then add it again to get that tab to come on again
next time don't disable it as it is there for a reason and that is to allow for other options
Apr 15, 2017 | HP Photosmart 2575 All-In-One Printer,...
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
2 sided option grayed out under Document Style
This option is grayed out because you do not have a duplexer inside the machine or its an office machine and they have it locked
Feb 17, 2009 | Sharp AR-BC320 All-In-One Led Printer
Disable the print microsoft office 2007 (enterprise edition)
May 07, 2008 | Microsoft Office Professional 2007 Full...
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
Microsoft Office Professional 2007 Full Version for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
