Question about Cameras
We have Ademco Proxypoint Access Control System but the Main Logic Board is bad and need replacement. We have not been able to find a replacement. Could we get the board or is there a replacement version. Model: MLB SA12000S
Slinteriors
  • 8617 Answers
SOURCE: Hitachi
Without the correct meters and equipment it can get exspensive replacing boards however it almost has to be located on the power filter or the power board. I would suggest the power board over the power filter.
Posted on May 16, 2008
Slapnuts1975
  • 51 Answers
SOURCE: Sanyo main board
Sanyo 1-800-877-5036
Or... www.shopjimmy.com for used parts.
Posted on Aug 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Posted on Aug 18, 2009
szanti
  • 36 Answers
SOURCE: How to identify the model number of a Ademco Alarm
on the top of the circuit board there should be a green lable with the writing P10 P15, P20.
P15 is a Vista 15, P20 is a Vista 20. You can find more info on honeywellsecurity.com.
Posted on Nov 20, 2009
Testimonial: "Thank you Szanti & Fixya...I received information from Honeywell support that the board/model is Ademco Vista 12. Regards Edward "
SOURCE: PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Posted on Dec 06, 2009
Aqua logic aql-ps-8 no power
The description indicates the unit has eight relays. There could have been a relay failure that caused the loss of power.
Dec 02, 2013 | Hayward Industrial Products Hayward...
How do i change my code on an ademco m6673 without knowing the master code?
How to find the master or installer codes for an Ademco ...
security.livewatch.com/.../how-to-find-the-master-or-installer-codes-for-...
Aug 7, 2009 - ... Ademco ?€?Vista series?€ alarm system and you don?€™t knowwhat the codes are. ... The master code is the main user?€™s regular code, but different than the ... Be advised that an installing alarm company will not and should not... The master code can change or add the other SU?€™s as needed ...
Need to reprogram an ADT/ADEMCO system - DoItYourself.com ...
www.doityourself.com/.../295048-need-reprogram-adt-ademco-system.h...
Feb 17, 2007 - Purhased a condominium 2 years ago with an ADT/ADEMCO system. ... Received no manuals of any kind but MAY have gotten a "Security Code" from seller. ... To change the master code the system needs to be in regular run mode, .... myalarm system was working but i went and acted like Reset Master Code for Ademco 4111XM, Via30+ or VISTA 10 ...
Jul 8, 2007
Ademco vista 20P with FC and Comm. Failure
Nov 8, 2005
More results from www.doityourself.com
[PDF]VISTA-20SE, VISTA-20HWSE User Guide - Honeywell ...
Oct 11, 2013 | Vacuums
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
Model #50PC1DRA no picture but we have sound we replaced the zsus board and main logic main board and still no picture
Hi
Thanks for using FixYa. As you have already replaced the Z-sus and the main logic board then the issue seems to be with the Y-main and/or Y-sus board. You’ll need to take the back off and check for any blown/bulged capacitors that might have gone bad and causing this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 02, 2010 | LG 50PC1DRA 50 in. Plasma Television
HI! I BOUGHT NEW CONDO WITH ADEMCO SECURITY SYSTEM MODEL 6128RF. I DON'T KNOW THE CODE TO ACTIVATE IT.IS ANY WAY TO FIND THE CODE? THANK YOU!
Yes but, what you have described is a basic keypad that can receive signals from wireless components of your system. What you need to find is 1) the transformer for the system ( usually tan about 2.5" square) and the main control box 15"tall by 12" wide (inside will be the back up battery) You will need an owners manual and a installation/programming manual for your system. The manuals are available online or post your info here. The door of the main control will have sticker saying which model you have. Now you should be able to follow the directions and be up and running in less than an hour if everything is working properly. If not, you may have a variety of batteries to replace.
Oct 28, 2009 | Honeywell 5804 Ademco Wireless Security...
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
Com1 port on a Zebra 105Sl not working, deleted & reloaded drivers still no go
Sounds like you have a bad main logic board. Unfortunately, the interface is built into the logic bd thus having to replace the main logic board assembly.
Please contact me if you have any question or if a board is needed. I have them in stock right now and can offer to do it on exchange for you bad one.
Please let me know.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 E240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 08, 2009 | Zebra 105SL Thermal Label Printer
Cameras Logo
46 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
