Question about Maytag MZD2766GES Side by Side Refrigerator
Rcw2000da refridgerator drain tray or tube clogged
Water pouring out of the bottom
Oh you don't want that.
Jun 18, 2017 | Refrigerators
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
Refrigerator drain tube
Hi Joe:
Look at the back of the refridgerator. Typically you will be able to see the drain tube running don the back and into an evap tray underneath. Sometimes the drain tube will get plugged with nasty stuff at the evap tray, or inside the fridge at the drain entry. Cleaning the components, and blowing through the tube to make sure it is clear should solve the problems.
Mar 19, 2015 | GE Profile PFS22MIW
Water leaking into fridge
Drain system is most likely clogged. The top of the frig is a tray that collects condensation. This runs down a tube down the back of the frig. Remove the tray, clean exit hole and check to see if drain tubing is clogged. Fairly easy to do, just pay attention to what order you take things off and just reverse the order to put back together
Mar 27, 2012 | Refrigerators
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have an Amana TZX21Q2W Referidgerator/Freezer on Top. I have a freezer drain tube that is clogged (probably blocked by ice.) I have the back panel off the freezer and can see the fan/condensor unit but I...
Double check your model number because TZX21Q2W does not come up. With the freezer panel off use a wet and dry vacuum cleaner if needed and if you pour warm water and some clorox you will find where the drain is. The only two places it could be and that is on top of compressor or inside the condenser area so the fan can blow over it to return the water back into the air. Be right back with some links, Sea Breeze
Dec 21, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Amana refrigerator 20 condensation water in fridge
moisture in the freezer is condensed at the back in a tray that has a drain with a tube that drains to a tray at the bottom of the unit. In our case the drain was clogged and water froze in it. We removed the back panel and pulled out the tube from the drain spout. We then used a hair dryer to defrost the ice clog and a wire to route out the drain and the tube. This worked and we replaced the tube and sealed it with tape. It now drains properly into the tray.
Sep 13, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
