Question about Amana Refrigerators
ASD2522WEW00 Amana Flap on ice maker dispenser stays open and causes frost in the freezer. Water works fine. Is there a switch we can replace ourselves? Warranty just expired - of course! We keep a wadded up plastic bag in ice dispenser area and remove it, jiggle the parts a bit and it will then dispense ice. HELP! Thanks for whatever advice you can give a senior citizen!
  • do3ed0ba Aug 28, 2010
    Thanks - just the info we needed. Guess we'll just call the repairman and have someone else do the job! What you describe fits our problem exactly. Good job!
  • 259 Answers
The flap that is supposed to block the opening has a spring that returns it to it's closed position.
The problem is most likely that the pin that retains the flap up inside the ceiling of the dispenser housing has broken away from the tabs.
There is a repair kit that you will need to get if this is the case. You can access the area by removing the dispenser trim and then the control bracket (grasp trim and pull forward to disengage, control bracket has retaining tab on left and right side). This will allow you to see what is broken inside the dispenser area.
If you do find that the steel pin at the top is broken you can order the repair kit that contains a new design steel bracket that gets installed into the top of the dispenser area to retain the pin.
I will be honest that the repair kit is a pain in the neck even for me to install.
The repair kit part number is: 8201756 and costs about $100 on average.
Good luck with this!
Posted on Aug 28, 2010
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
I have a KitchenAid side by side and my icemaker is not working
Check the black 2" fill hose going from the top of the freezer to the ice maker fill cup , to see if it's frozen up . Also check the optics system for proper operation . Open the freezer door and the laser should flash 2 times , pause , flash2 times , pause etc. Close the flap on the left side and the laser should go off . If the laser does not come on when the door is opened , then the ice maker is in the harvest ( dump ) mode . If it stays this way , then ice maker is bad .
Sep 12, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker flap stay open
the solenoid is bad,next time send the full model number it says it's a ge so this should help you out,for now you can get a ball of paper towels and stick it into the shout where the ice comes out to stop the warm air from getting into your freezer
https://www.youtube.com/watch?v=jpXo0svta9s
Feb 07, 2018 | GE Profile Arctica Stainless Steel Top...
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
125 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
