Question about Microsoft Windows Vista Ultimate Edition
Vista Word Define Multilevel Format
How do I format new Multilevel List. I am trying to form a list with the numbers, 6.0 Heading 1, 6.0.1 Level 2. The problem is that I can't seem to input the 6 & 0. The 6 is highlighted but the 0 isn't and when I am trying to form the list, instead of going from 6.0 to 6.1, it inserts 7.0.
Can anyone help with a solution?
Whats do vista mean
Posted on Jul 23, 2008
Wasas
Posted on May 09, 2008
How can chapter titles be inserted into an existing document in Microsoft Word 2010?
Insert The Chapter Number And Title In A Header Or Footer
First divided your document into sections in order to insert chapter numbers and titles into headers and footers.
1. If you haven't done so already, insert a section break where you want to start a new section that contains a different chapter.
a. Click where you want to insert a section break.
b. On the Insert menu, click Break.
c. Under Section break types, click the option that describes where you want the new section to begin.
Note: If you have already inserted a page break to cause the chapter to start on a new page, delete the page break and replace it with a section break that starts on a new page.
2. Apply a built-in heading style to the chapter number and chapter title by clicking a heading style in the Style box on the Formatting toolbar.
Or to have Microsoft Word automatically number headings, use the Bullets and Numbering dialog box to format chapter headings.
a. On the Format menu, click Bullets and Numbering, and then click the Outline Numbered tab.
b. Click a chapter-numbering style (one that includes the text "Heading 1" or "Heading 2," and so on), and then click OK.
c. Type the text you want for the numbered heading, and then press ENTER.
d. To add the next numbered heading, go to the next chapter heading, click the arrow next to the Style box on the Formatting toolbar, and then select the heading style you specified in step 2.
1. In the first chapter, on the View menu, click Header and Footer.
2. If necessary, move the insertion point to the header or footer you want to change.
3. Insert the chapter number or title.
a. On the Insert menu, point to Reference, and then click Cross-reference.
b. In the Reference type box, click Heading.
c. In the For which heading box, click the heading that contains the chapter number and title.
d. In the Insert reference to box, select what you want to insert in the header or footer. For example,
• Click Heading number to insert the chapter number.
• Click Heading text to insert the chapter heading.
e. Click Insert, and then click Close.
4. Click Show Next Button image to move to the header or footer of the next chapter.
5. If the header or footer in this chapter matches the one you just created, click Link to Previous Button image on the Header and Footer toolbar to break the connection between the header or footer in the current chapter and the previous chapter.
6. If there's already text in the header or footer that you don't want, delete the text before inserting the chapter number and title.
7. Repeat step 5 to insert the chapter number or title of the current chapter.
8. For each chapter in the document, repeat steps 5 through 9.
Aug 04, 2014 | Microsoft Word 2010
Auto Numbering in Word
You can use the multi-level list. This should work easily.
Apr 07, 2014 | Microsoft Office Word 2007 Full Version...
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
I recently purchased the device listed below and when I ried to use I received a message that it was either not formatted or formatted for a Macintosh. How do I format it for use with my Dell PC?
Your usb stick could be formatted in either 2 ways:
1) If you go into "my computer" or "computer" (depending on if you are using XP or Vista/7) and you see your usb stick on that list, you can right click on it and select "format". You can just accept the defaults it gives you and hit ok and it will format it to be used on your computer. If it doesn't show up in "my computer" then there is another thing you can try:
2) If you right click on "my computer" or "computer" there will be a menu that pops up, select "manage" from this list. Once a new windows opens up, on the right hand side you will see "disk management". Select this. You will now see a new list of all the hard drives/usb drives on your system. You can right click on your usb stick and hit "format" in the same way as 1.
DISCLAIMER: Make sure that you select your usb stick from these lists, and not your computers hard drive. If you accidentally format the hard drive you will lose everything on your computer.
Hope this helps and if you need any more help just leave a comment here and I will get back to you.
Sep 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Dear Sir, My HDD Details : - Model : HD161GJ HDD P/N : HD161GJ LBA 312,581,808 160.0GB S/N : S14DJ90Z446270 P/N : 61763-A71A-A63JX my problem is on this HDD any OS installed, this OS In...
You may have a bad sector where the OS resides on the drive. Download what is called a low-level formatter. This software is designed to lay down the actual tracks where data is stored. It is different that formatting with the OS. This will put the drive back to the original unformatted condition. After you do the low-level format, you will need to format the drive again with whatever version of OS you use.
Apr 16, 2017 | Computers & Internet
I would like to change the greeting when someone calls our number... for example, "dial one for front desk, 2 for gm and so forth....any tips??
Hi...u can do this setup by uploading a recorded greeting in wav file format in system audio update form..then assign those dial1,dial2..to multi level auto attendant programming(MLAAP) in voicemail form...from there u can define the destination extension#.
Oct 13, 2009 | Mitel 5212 IP Phone
Barracuda 7200 6Y160M0 FW YAR51HW0
do a low level format with a software from hddgurudot com its free software. run it and choose this drive for low level format.it runs through windows it will make a new list of bad sectors and add it to the p list of the hard drive company settings
datarecoveryfactory
Jun 09, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Can't recognize caller's name when including country code
Easy. (hope not too late :))
1. Press green phone button (as making call, list of recent calls appears).
2. press "menu", go into "options", then go to "smart dialing".
3. Choose correct "country code" and "national number lenght".
4. save.
Good luck! (Pearl is the best phone ever, you just have to use some brains to make it usefull :) )
Mar 21, 2009 | Apple iPhone 3G
Microsoft Windows Vista Ultimate Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
