Question about Sony Playstation 3 (PS3) Console
Very mysterious picture problem
Everything starts up normally but i will list the following problems i have with the picture quality on my ps3
1. when i play music, the earth and other scene are covered by this green to red to yellow picture, i can barely see the scene
2. when i view pictures there are red and green dotted lines scattered horizonally acroos the picture, when u zoom in sometimes they dissappear for a few seconds
3. when i view saved video clips there are red and green horizonal lines that flash across the screen, mainly on the edges. the same thing happens with movies of all types.
4. when i play Warhak the tanks, warhawks, characters will usually be neon green or a bright burgundy color and super white. the ground has sporadic black dotted lines.
5. when i use the internet browser sometimes it shows a normal picture. if it doesnt i can exit the browser and enter again and repeat until i get a clear picture, but it only lasts about ten minutes. if i zoom in on the dots they seem to be a tiny square divided in 4 different shades of the dot all moving and changing different shades
6 when i play the new gta i have to walk through wierd polygonal shapes that appear and disappear depending on which way i have the character facing, but they are always in sight in the distance. they are not solid masses unless they are what the game has put there. i can walk and shoot through them.
i have replaced all the cables and have performed two sytsem resets and no fix. i even went as far as buying a 1080p lcd tv and tried the hdmi cables and resulted in the same problem.a computer tech friend of mine said it could be a bad video card or a virus. do u think u could figure out the problem? please help me with this problem
thanx guys
pedro
  • upaydro6
    upaydro6 May 07, 2008
    when i play songs
  • upaydro6
    i bought it in september of 07. im gonna try wat u have suggested. if it does not work, how do i get in contact with sony and what adress do i send it to? and any idea on how long it would take?
    Genius:
  • 1,226 Answers
I figure out your problems! Maybe you use a very low pixel video card on your computer. or maybe your need a correct driver of your video card. if your video card is built in to the board you should inhstall the CD utilities enclosed to your computer from the vendor. if it is an add -on video card you need also to install the video card driver in it. if you install it before and ex[perience an error. maybe you need to uninstall the driver and reinstall it again. There is no virus cause in this problems only the video card and driver of the hardwares.
may this help,
melnavz
Posted on May 07, 2008
  • Emelio Navaja
    Emelio Navaja May 08, 2008
    hello,
    Sorry i miss interpret the your first question.
    This site can help you how to contact the sony .. http://esupport.sony.com/US/perl/contact...
    I guess that the ps3 projection screen got some errors in the setting ..Did you try unplugging in the wall outlet and then replug it again. to hardly reset the setting. if not solve then thats the time that you need your ps3 to personally check by the sony accredited repairman in your area.
    may this help,
    melnavz
  • 156 Answers
I'm sorry to say pedro but your computer friends first instinct was correct this is a faulty videocard and or drivers.
how long ago did you purchase your PS3?
You said you did 2 resets but Have you reset the PS3 to Factory settings? If you did factory reset it did you test the same problem before uploading your backups onto the PS3?
If not do a system backup
This is how to do a Factory Reset on PS3
1. Power Off the PS3 in back and power back on
2. Hold power button on the front till you hear 3 beeps.
3. Then go through the setup and then run a Full Format from System -> Format. You may need to have your AV cables if your using HDMI (in case its not detected after reset)
4. Test the same problem with the same game
5. If still doing problem restore your backup you made prior to doing factory/hard reset
6. Contact sony cause you need a repair.
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
I need a projection lamp on a rear projector Sony TV model # KV-13FM13
Hi HG Allen,
Search Amazon or Google with your model name and the word Lamp replacement. You will find some lamps listed as "OE" which means it fits like original equipment (lamp) but it's an aftermarket lamp and is cheaper in price and quality. These lamps most of the time do not last beyond 3 months and the light output is weak so you picture is noticeably dimmer.
If you find an "OEM" listing and it says "Philips" or "Osram" then those are the quality lamps that are quality made and will last and your tv picture will be brighter like it was new again.. I hope this helps you.
Aug 29, 2014 | Televison & Video
I'm having problems with my resolution. Everything that is a circle like icons and pictures have shrunk into ovals.
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Sep 05, 2011 | Computers & Internet
Screen too big on facebook game Mystery Manor and cant see to play cuts off scene all around it.
always click APPLY after making any changes hope this helps
May 24, 2011 | Computers & Internet
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Picture quality for gaming
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Apr 28, 2009 | Samsung PS50A457 50 in. Plasma TV
Picture Quality Iphone
This is normal. Most pictures you see on websites are small representations. Try going to a wallpaper or background website, click on larger pictures and zoom in then.
As for Youtube, this is normal to have ratty quality videos. this is also dependent on your bandwidth, so it may drop in quality in a low reception area, but wifi should be pretty decent, just still typical YouTube quality.
Mar 10, 2009 | Apple iPhone 3G
Blurred picture
Hitachi > 53FDX20B blurry picture
I would start 1st by checking all resistors ie.
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
If I were you I would also replace the convergence chips. From the above thread it's clear that they are of different quality so they may last different lengths of time (B&D is a good place to buy good quality ones).
I found a free pdf service manual for 53FDX20B on a Polish web site: http://instrukcje.elektroda.net/main1750.html
other models try here: http://www.webtronix.ca/hitachi/index.htm
http://www.asm-service-manual.com/List/Hitachi%20List%20ASM.htm
Download pictures from my repair (Password: delirious).
http://www.uploading.com/files/HGGLJLXC/Delirious.zip.html
Jan 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
