Question about Canon PIXMA iP1800 InkJet Photo Printer
Tengo un problema la impresora no imprime y me sale un error 5202
  • 848 Answers
SOURCE: mi problema es que tengo
tell me your problem in english ....... i could not understand this language
Posted on Jun 24, 2008
ginko
  • 19396 Answers
SOURCE: TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Posted on Sep 27, 2008
MXM450
  • 62 Answers
SOURCE: sale una raya negra en la impresion
tambor
Posted on Jan 22, 2009
rulds2008
  • 3866 Answers
SOURCE: tengo problema con la impresora hp photosmart
debe a reinstalar el programa o arrcadora de HP. Si eso no fuciona debe a chekar si la foco de escanner esta fucionando correctemente. Ese problema es de arracdora/driver que llavar Hp. Debe a reinstalar de programa.
Gracias
Posted on Apr 22, 2010
  • 304 Answers
SOURCE: tengo un problema con la
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Posted on Jul 14, 2011
Hola el problema que tengo es que la impresora copia muy oscuro y en un tomo chocolate quiera saber que puedo hacer en este caso gracias
Empezando, qu? impresora tienes? Si es un Deskjet y est?s escribiendo en modo de "color", deber?as ponerlo en modo de "black". Independientemente a eso, posiblemente tienes uno de los cabezales funconando incorrectamente de tal forma que el resultante de la impresi?n en vez de "black" sale marron.
Imprime los colores b?sicos para verificar cu?l es el color que causa el problema para reemplazar el cartucho o cabezal
Apr 18, 2015 | Office Equipment & Supplies
Tengo una i,presora HP P4015n y ne sale un error 49.FF04 error turn off then on, como soluciono este problema?
Tengo un problema con la i hp 4014n, de repente empezo a imprimir los documentos con partes en blanco o imprime algunas partes otras no... marca error y no se puede imprimir el documento pero lo imrpime igual solo q con este problema
Sep 19, 2011 | HP LaserJet P4014n Printer
Tengo una impresora EpsomTX300f tomando fotocopias me imprime pero me produce una sombra en toda la hoja, esto me la hace muy lenta como hago para solucionar este problema. Agradesco su pronta ayuda.
Que tal.
Este problema puede ser causado por varias cosas. Entre ellas una mala configuración de los drives de la computadora, trata descargandolos desde la pagina oficial de Epson. También puede tratarse de un problema con los cartuchos algún defecto de fabrica(pequeña fuga). Si los cartuchos son rellenados, puede que no sean reconocidos de manera correcta por tu impresora.
Saludos.
Aug 28, 2011 | Office Equipment & Supplies
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
TENGO UN MENSAJE QUE DICE: CUBIERTA TRASERA ABIERTA,COMO PUEDO SOLUCIONAR ESTE PROBLEMA EN EL PRINTER MFC-7820N\r\n GRACIAS
La solucion que me ha funcionado para una Brother DCP-7010 ha sido:
1.- Abrir la puerta trasera
2.- Bajar la cubierta trasera que esta justo delante del fusor. Para ello he pulsado hacia abajo las dos palancas de plastico azul en los laterales.
3.- En el interior de la cubierta, en la parte inferior derecha hay una barrita de plastico horizontal que aproximadamente en la mitad tiene un saliente (una barrita perpendicular de plastico). Dicho saliente debe estar metido en una ranura que tiene la cubierta trasera, en mi caso se habia salido.
4.- Una vez metido el palito en la ranura se cierran todas las puertas.
5.- Ponemos en marcha la impresora y vemos que ha desaparecido el error y ademas imprime.
Saludos.
Mau
Oct 10, 2010 | Brother MFC-7820N Printer
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
106 people viewed this question
old marine
old marine
