Question about Viking VIPR161 Kitchen Hood
Viking Control Board Model VIPR161SS Part - Viking VIPR161 Kitchen Hood
The Light on the front panel of my microwave does not light up.
Probably a faulty control board but without make and model that is a rough guess.
May 19, 2017 | Microwave Ovens
What is the cost of a motherboard for the Viking refrigerator model VCBB363RSS
no mother board
high volt board,low volt board, inverter board for compressor
with out looking up 200-400 each depending if can$ or us$
Jan 31, 2017 | Viking Refrigerators
DFRB364R Viking is freezing up
this unit is operated by a main control board. need to pull all shelves and pull rear panel and test with multi meter the heater and defrost thermostat. if both are good replace board.
Dec 16, 2015 | Viking Refrigerators
Model DED0530 wall oven. Tries to start but then why does it indicate 'cooling error lower one'?
[PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m1300016_f20366.pdf
Viking Rangecontact our consumer support center at 1-888-VIKING1. We appreciate your choosing a... Error Handling .... *Note: Professional Series Premiere model control panel and features are shown. Oven ... upper or lower oven, and then set the desired temperature. .... cooled, remove any ash from oven surfaces with a damp.
Nov 06, 2015 | Ovens
What does error code "Key Short Err" on Viking dual fuel mean?
Hello. That type of error usually means that there is a shorted button on the control. I don't know the model number so I can't look up the part. The button control panel is usually known as the "user interface" in repair lingo. Be prepared, the user interface panel is normally more expensive than the main control board. If the unit has "soft touch" buttons one of them probably is shorted out(giving the computer the impression that you haven't removed your finger and it's still being pressed). If it's one of the fancy capacitive touch panels(you just touch the glass to select), the circuit board has a defective chip and must be replaced.
Aug 31, 2015 | Viking Kitchen Ranges
Model 2060
Sounds like some type of power surge and now either the control board or motor has gone bad. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Jun 13, 2014 | Husqvarna Sewing Machines
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
My Husqvarna Viking 980 continues to sew when I take my foot off the petal. Sometimes the stich get very tight when this occurs. Could this be the foot petal or is my circuit board going out?
I have never seen it be the circuit board, always is the foot control switch. I dont understand the stitch getting tight though. And yes, it could be the circuit board.
Mar 07, 2009 | Husqvarna Viking 1
Viking VIPR161 Kitchen Hood Logo
374 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
