Question about Bosch 4000 - 07 Electric Table Saws
Saw blade seems to be seized, it is hard to turn manually.
  • 2,176 Answers
Could be a couple problems, first is the inner flange on correctly. and if so remove the blade UNPLUG SAW FIRST and see if you can turn the spindle by hand, it should spin freely, if not then you have a bearing problem or possibly the motor is burnt. did you notice any burning smell last time you used it and if so that is it. Let me know
Posted on Aug 30, 2010
Northern Tool 10" compound miter saw. How do I change the blade?
remove the power cord from the socket in the wall first
if there is a small hole in the blade , place a phillips screw driver in that hole and turn until the driver is locked against the depth guard
use the correct size spanner /socket and undo the spindle nut holding the blade on
if there is no hole ,then place the screw driver in the teeth of the blade to lock it
the motor will spin so that the teeth cut against the direction of cut ( up into the guard or up through the depth guard ( blades normally have a arrow for rotation direction)
tighten the spindle nut and if no hole in the blade use a hammer and hit the spanner with a hard rap
Sep 30, 2015 | Saws
Cannot get blade off my worx easy cut saw
Try turning the nut the opposite way. It's possible the saw has reverse threads.
Aug 18, 2014 | Saws
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
I inherited a very old Fury F-7 circular saw from my Dad. It uses a 7-1/4 diameter saw blade. This is sorta-kinda embarrassing, but for the life of me I cannot figure out how to lock the shaft to replace...
Most times when I need to change a blade on my 7 1/4" saw I simply grab the blade on the front side, below the saw's support table, with a pair of channel lock pliers and then use the box end wrench on the blade nut, pushing down from the back side of the saw blade. That should loosen the nut so you can take it out with your fingers. The reverse of this procedure should tighten the nut on a new blade.
I'm not real familiar with the Fury saw, but if it requires saw blades with the diamond shaped cut-out in the center, most of the older blades had a knockout that will fit the diamond shape it would need.
Apr 22, 2011 | Now Evolution #Fury 7 1/4" Mp Circular Saw
Have a QEP 24" bridge
blade might be to tight, loosen the nut that holds the blade,if that dont work,blades gotta be hitting something,if its a new blade measure it up to your old one to check size,make sure its a wet cutting blade,some continuous rim blades are made for hard material like granite,or dry cutting , good luck
Feb 17, 2011 | Saws
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
Rowdy, The blade seams stuck. It wont spin freely even . I took out the blade and inspected the spindle. I didn't see anything that looked out of place. the motor turned hard without the blade attached....
check the bearings, especially the commutator bearing for seizing up, this is a common problem for the table saws. Let me know the exact model number and if you have a bearing puller you can fix this easily. if not most shops won;t charge much to pull and press on new bearings.
Dec 29, 2009 | Bosch 4000 - 07 Electric Table Saws
Delta 10
Replace the blade. It is very dull. Cherry is very hard wood and should be only cut with a very sharp blade.
Nov 13, 2008 | Saws
Bosch 4000 - 07 Electric Table Saws Logo
208 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
