Question about Nikon COOLPIX S200 Digital Camera
Nikon coolpix s210. no damage, no dropping of the cam. just a sudden lens error msg . power on, the lens goes out, tries to focus for about 3-4 sec. and then the camera shuts off. any ideas? thanks, dawn
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
I Have a Nikon Coolpix S210, the lens is stuck in the extended position and I have no pictures on the screen. I have at times seen that when I turn on the camera and the power light is on, it tries to...
Here are some ideas. Once I solved such an issue on a camera that had fallen down on a hard floor (by applying force on the lens to make it retract)..but please read everything here first *before* you try that:
http://www.wikihow.com/Repair-Lens-Problems-on-Your-Digital-Camera
Nov 28, 2010 | Nikon Coolpix S210 Digital Camera
Hi im trying to find out how to fix a nikon s210 lens
Try to reset the camera or take it into Nikon it might be damaged
Dec 13, 2009 | Nikon Coolpix S210 Digital Camera
Nikon cool pix lens error and will not focus
To things to try. 1. clean the battery compartment with a Q-Tip "dampened" in some rubbing alcohol. Do this to the battery and the charging station also.It just occured to me that you cannot get into the main menu because the lcd is black. I "was" going to suggest also resetting the cam to it's factory defaults. Try the first one it has worked for me many many times.If it does not work than you may need a new battery. The indicator on the LCD screen is NOY always accurate for battery readings. Good luck, my friend, Dana
Sep 07, 2009 | Nikon Coolpix S210 Digital Camera
My 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Jul 31, 2009 | Nikon Coolpix S210 Digital Camera
My nikon coolpix s210 has a lens error. I turn it on and the lens comes out. It make a err sound and seems like it cant focus. it goes back in and says lens error until i turn it off. I need it. I cant...
if its brand new, then you can replace the lens array for free of service charges in the case you have all the documents. it generally happens if you have dropped the camera.
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
S210 coolpix lens error and wont focus
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 31, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
265 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
