Question about Kitchen Appliances - Others
Pendant ceiling light .Light will not switch off
  • 377 Answers
If it is an in-line switch, a switch located between the plug and light, usually interwoven in a chain, it can be replaced. If you are handy, you might be able to fix the switch you have. There is not much to them. Perhaps screws holding it together have come loose and created a short. UNPLUG IT and look the switch over. Usually held together by two screws.
Posted on Aug 29, 2010
New lighting system installed with six ceiling spots and six pendant lights, controlled with a single switch.
This is a possibility .
I have experienced this when a mouse bit through the wiring in the wall from a light switch to a light .
Mar 20, 2018 | Motorcycles
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Wire a westinghouse mini pendant
if you have 120 volts on the white and red in the ceiling,try hoohking the blue to red if this is a light kit for a ceiling fan.hope this helps.
Jan 27, 2018 | Dryers
Ceiling fan switch the new switch bought has 3 wires and the old one has four wires
if the ceiling fan work regularly ,it only have one wire .but it has 3 wires . so you should cut two off .which should be cutted of ..you should switch the wire one by one .
ceiling light
May 10, 2012 | Solar 2-wire Pull Chain Light Switch For...
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Installing pendant lights in series.
Chances are you're crossing the live wire directly to ground. Do you have 3 wires for hookup? If you do, 1 is live, and 2 are grounds. I would try every combination. If it doesn't work in any of those connections, the strip may be defective.
Mar 14, 2010 | Hampton Bay 24750 Huntington III Ceiling...
In changing out an incandescent light bulb in a ceiling mounted light fixture, the glass hanging pendant was loose, so I removed the fixture from the ceiling, leaving the wiring connected, and tightened...
Many times with very old wiring the wire can break inside the coating and not be visible. To check for sure what has happened you will need an electric tester. You will need to check for 120 volts acros the two wires with the switch on. If there is no power, then check at the switch. If there is power there then the wire is broken.
Replacement of the old wires in an old house is very difficult and you will probably want to hire a professional to do that.
Heatman101
Feb 28, 2010 | Hampton Bay 24002 Ceiling Fan
I currently have ceiling roses and pendants but most of nice lights are flush fitting. Is there any way of fitting these without pulling floor boards up!
Flush fittings can be used in place of pendants/ you need to make sure there is space above fitting for it to Breath, also you can buy Fireproof hoods for fittings that a good idea if using low voltage lighting as it produces a fair bit of heat,When you remove pendant you will see the wiring, always ensure all screws are tight avoiding loose connections and of course kill power before starting..good luck
Nov 05, 2009 | Coffee Makers & Espresso Machines
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
