My samsung front load washer is flashing a nF code. what does this mean?
jsrock516
  • 5911 Answers
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on May 13, 2007
SOURCE: I have a front loading
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Posted on Sep 16, 2008
duby1990
  • 367 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
pride applia
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
What does flashing nf sign means on the samsung front loader
It means "No Fill". NOt enough water is making it into the washer. Make sure your water connections are good and hoses are not kinked.
Jul 24, 2016 | Samsung Energy Star 3.9 Cu. Ft. Front Load...
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
What does error NF mean in front loading machine?
NF stands for No Flow. Check to see that your valves are open and that water is getting to your washer. If you have water to the washer, you my have a problem with the selenoid valves that control the water flow.
Oct 04, 2014 | Samsung WF328AA Front Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
In the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
Oct 09, 2009 | Samsung WF337AA Front Load Washer
Hi... My washing machine... samsung front load. will stop in the middle of the wash and beep and flashes nF. We had bought the floor model and when we got it home realized we didnt have a manual... I can...
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
Jan 16, 2009 | Samsung WF337AA Front Load Washer
Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Nov 24, 2007 | Samsung WF337AA Front Load Washer
Washing Machines Logo
257 people viewed this question
Top Washing Machines Experts
