Question about Keurig B100 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
  • 2,272 Answers
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Aug 28, 2010
  • 1 more comment
  • uponthecouch Jan 08, 2011
    Wow I didn't have to do all that, I have a B70 that said auto off set and:
    All I had to do was rock the on off switch on the bottom in the back, then se tthe auto-off to off:
    1. press menu until auto-off is selected
    2. press hour until 'off' is selected
    basically something went wrong in the menu settings, could also have an off-time selected. Didn't have anything to do with the water reservoir or needle.
  • LLLLL Jun 22, 2013
    I\'ve been having problems all morning where it wouldn\'t draw water, and as soon as I followed this it worked!! After two hours of playing with the thing, thank you thank you THANK YOU!!!
  • Susan Grizzle
    Susan Grizzle Aug 29, 2014
    Thank you so much!! it worked !! it fixed it!!
Not ready off set.. troubleshoot does work thank you...
Posted on Dec 16, 2013
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else...
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Nov 22, 2013 | Keurig Platinum B70 Coffee Maker
Keurig B60 error message "not ready" and ""turn off auto off"
Button on Auto needs to be depressed and turned off. See manual.
Oct 10, 2012 | Keurig Special Edition B60 Coffee Maker
Keurig B60 will not stay on
Turn off Auto Start. see manual page 17 for indstructions.
Feb 23, 2012 | Keurig B60 Coffee Maker
Screen says "Brewing" and it
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 14, 2011 | Keurig B60 Coffee Maker
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
I set the auto off on my new Keurig and it has now locked me out. The led display is flashing "Not ready, auto off set". Any button I press does not allow me into the menu to change settings....
Sorry to read about your problem, I hope this helps you out.
unplug the unit, that should solve your problem..then re program
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Keurig B60 Coffee Maker
B60 won't heat
check and make sure the resevoir is full and that the float switch in the resevoir is not stuck.
Jul 22, 2010 | Keurig B60 Coffee Maker
Keurig B100 Coffee Maker Logo
7,555 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
