Question about Samsung Computers & Internet
I have a Samsung N150, I was using it this morning until it ran out of battery, now I have plugged it into to the charger but the lights haven't come on to indicate it is charging and it won't switch on, how can I fix this?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
Samsung n150 screen
contact samsung service center may be a battery issue or major issue with bios
Oct 20, 2013 | Computers & Internet
Samsung notebook N150 Plus has gone completely dead
Try another AC outlet, try another cord/charger of the EXACT same power spec. Has the AC jack in the computer been damaged by pulling on the cord? Power surge? With a multimeter, verify DC volts at ac cord plug. Is the Laptop usually left plugged it when not in use? Do you shut it down and unplug when not in use?
Jan 20, 2013 | Samsung N150 Notebook
Samsung n150 charger light blinking green
This might mean low charge current. Try replacing the charger. It worked for me.
Aug 04, 2012 | Samsung N150 Netbook
Phoenix failsafe 16 code key
Contact (MJ_Park@phoenix.com) Thats who gave me mine. I messaged him at 1 in the morning and got a password 20 minutes later.
Nov 14, 2011 | Samsung N150 Notebook
My samsung n150 plus is although plugged in, the battery information describes that "plugged in but not charging"
my samsung n150,although plugeed in charging port displaying not charging..what is the solution for this problem..reply on vvvswathi@gmail.com
Apr 19, 2011 | Samsung N150 Notebook
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
Computers & Internet Logo
145 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
